Sealing water seepage in concrete underground is a futile exercise. The water will find a new way to get in. Concrete is a porous media, and the water will just a find the next less resistive path to flow. Now, if the seepage is coming from a crack, that's a different story. But if it is coming from well cemented blocks, the only way to stop the seepage is to improve or put drainage around the offending wall.
How do I know this? We went through this in our Townhouse complex. Exact same scenario. Tried all kinds of cheap fixes. In the end, a drain pipe too which buts tree roots and clears the pipe did the trick, along with a reverse flushing.
Gary
