Old 12-13-07, 03:02   #1 (permalink)
Stryder is offline
Electric Impact Wrench???
Would an electric impact wrench that has about 345 ft-lbs of torque be sufficient enough for jobs like changing the brake pads, rotors, and swapping out the suspension? I'm hoping an electric one and a breaker bar would be all I need for those tough bolts.
Old 12-13-07, 03:13   #2 (permalink)
1981 Camaro Z28
BigJimZ28's Avatar
BigJimZ28 is offline
Re: Electric Impact Wrench???
YES it will be more then enough
lugs should only be about 100 ft-lbs
so get yourself a tourque wrench also to put them back on
and find the tourque specs for your car
Old 12-13-07, 03:40   #3 (permalink)
Stryder is offline
Yea I'm not worried about the lug nuts, I'm more worried about suspension work. My lug nuts are supposed to be torqued at 80 lbs. and I have a torque wrench for that.
Old 12-13-07, 05:00   #4 (permalink)
jshillin's Avatar
jshillin is offline
Contact: Send a message via AIM to jshillin
Electric impacts don't seem to have the same torque or speed of pneumatic. I honestly would get something with atleast 450 - 500 ft/lbs. A lot of suspension bolts corrode and really need some torque to break them loose. I've used 2 electric impacts with ratings similar to that one and was pretty unimpressed.
Old 12-13-07, 06:12   #5 (permalink)
460ci. 450rwhp
ramtough's Avatar
ramtough is offline
Front or rear suspension
Old 12-13-07, 06:50   #6 (permalink)
Stryder is offline
Both. What about this model? The specs says it has a max torque of 450 ft. lbs.
RIDGID 1/2 In. Heavy Duty Impact Wrench - R6300 at The Home Depot
Old 12-13-07, 07:05   #7 (permalink)
MLindgren is offline
ALL brakes/suspension fasteners dhould be torqued to the manufacturers specs!
Old 12-14-07, 11:58   #8 (permalink)
jshillin's Avatar
jshillin is offline
You always want more than what you need.... Something might only be torqued to 100 ft/lbs, but a bit of corrosion or thread locker makes that almost impossible to break loose. You can always turn it back a notch or not hammer it when putting fasteners on, you need all of the torque to remove things.
Old 12-14-07, 12:16   #9 (permalink)
1981 Camaro Z28
BigJimZ28's Avatar
true but if that are that stuck I usually end up ripping the head off the bolt
I am a large guy and have a 25" breaker bar so it's comming off no matter how
corroded it is
so I stand by my answer to his question that it is enough
to have an electric one and a breaker bar
Old 12-14-07, 12:22   #10 (permalink)
Stryder is offline
corroded it is
Yes, I'm leaning towards an electric impact gun and a 25" breaker bar.
Old 12-14-07, 12:30   #11 (permalink)
jshillin's Avatar
jshillin is offline
The only thing about that is that a huge breaker bar doesn't fit everywhere you need it. I have a big breaker bar in all of my vehicles...
Old 12-14-07, 12:32   #12 (permalink)
Danase's Avatar
Danase is offline
I have a Chicago Eletric / Harbor Freight Impact Wrench I have had since about 1998. It's awesome. I use it all of the time too.
