Old 12-10-07, 07:08   #1 (permalink)
Burnout01 is offline
Garage Car Wash
I'm getting ready to start building a new house. It will have a 2 1/2 attached car garage. I'm curious if any of you have the ability to wash your car in your garage in the winter? I was thinking about having a drain installed and plumbing ran, but what do I need to do for the walls? Current plans have drywall being installed. I like the look of drywall but know it doesn't mix well with water. I've wondered if painting it with a latex exterior paint would work or if I'll just need to go with another material all together.
Thanks for any help or advice.
Old 12-10-07, 07:13   #2 (permalink)
joyriiide1113's Avatar
joyriiide1113 is offline
Re: Garage Car Wash
Oh man. You are one lucky man if you indeed end up making an indoor wash bay.
Unfortunately my post contributes nothing as I know NADA about it.
Old 12-10-07, 07:23   #3 (permalink)
JWNPlumber's Avatar
JWNPlumber is offline
Re: Garage Car Wash
Burnout, not sure if you could pipe in a drain to a garage floor legally by building code with out some type of grease trap. You may be able to get by with piping the drain into the ground but I would definately check the codes in your area. As far as the walls go a good idea would be the kind of material that your local grocerie store would have up in the meat department or deli area. I have seen it installed and if all of the seems are siliconed up tight you can hose it down.
Old 12-10-07, 07:31   #4 (permalink)
1981 Camaro Z28
BigJimZ28's Avatar
BigJimZ28 is offline
Re: Garage Car Wash
or just use ONR
Old 12-10-07, 07:35   #5 (permalink)
Re: Garage Car Wash
Will ONR be good enough after driving through Road Salt?
Old 12-10-07, 07:43   #6 (permalink)
1981 Camaro Z28
BigJimZ28's Avatar
Re: Garage Car Wash
there are prob. 100 threads answering that question
YES
if it is real bad $2 @ the coin opp first
Old 12-10-07, 08:33   #7 (permalink)
ZimRandy's Avatar
ZimRandy is offline
Wink Re: Garage Car Wash
Here is an older picture of my garage, but it shows the tin walls. When it was done being built, I used a pressure washer to clean the chalk marks from the walls. There is running water, a drain, and provisions for a restroom with a shower (no time or money to finish that part, yet)
Good luck with your garage!
Randy
Old 12-10-07, 08:57   #8 (permalink)
bert31's Avatar
bert31 is offline
Re: Garage Car Wash
If you have to, pull your car out of the garage and spray off with a regular hose (and pressure washer if you have one). Then pull it in and do a regular ONR wash, you will be fine.
Old 12-10-07, 09:28   #9 (permalink)
@hotmail.com
integritydetail's Avatar
integritydetail is offline
Contact: Send a message via MSN to integritydetail
Re: Garage Car Wash
grease trap will be necessary but its super easy. very cool idea. k-lite panels come in 5x8 sheets and most lowe's have it in stock. its just a vinyl like, white, thin sheet that you can go halfway or all the way over your drywall in the wash area. it looks pretty good, too.
Optimum Results demand Optimum Products*
*Great results can be achieved with any high end line. I use and recommend Optimum.
Old 12-11-07, 06:39   #10 (permalink)
boogiejoe's Avatar
boogiejoe is offline
Contact: Send a message via AIM to boogiejoe Send a message via Yahoo to boogiejoe
Re: Garage Car Wash
I wash my car regularly in my garage with drywall. I thought the drains would be code, or at least a good idea to let any water drain instead of sitting on the floor. I would think you would want a drain just from the snow your car brings in.
Can you wash your car without spraying all over the walls? When I wash, I don't park that close to the walls, and there is not usually much of a problem if you're careful.
Old 12-11-07, 06:44   #11 (permalink)
Setec Astronomy's Avatar
Setec Astronomy is offline
Re: Garage Car Wash
I think most people who contemplate putting in drains so they can wash in the garage live in climates where it is below freezing regularly during the winter, which makes spraying off the car outside the garage unpleasant, impossible, dangerous, or all three.
Grumpy like Ketch...
"Well, it certainly does!"
Old 12-11-07, 06:49   #12 (permalink)
Re: Garage Car Wash
It depends on your locale, but you will likely get a lot of resistance to being allowed to put a drain in the floor. The oil separator is a big deal, it's larger than you think it would be (and therefore deeper). If you're very lucky they will let you put a sanitary drain in, and I absolutely would do it, not only from a car wash standpoint but being able to hose down the garage (no oil down the drain, that will get you in trouble).
