Ok lets start with the basics. I am a newbie in using rotary but I have patience :P.
The victim...A black 2003 ford fiesta (this thing has a lot of metallic flake and lots of swirls)
The products...1z pro series, I have Pasta Intensiv (932715) ( I did not use it today), High Gloss Polish (932815) ( I use it with
meguiars 6.5 polishing pad) and Wax Finish (932655) (I used it with
meguiars 6.5 finishing pad).
To remove swirls I started polishing with
meguiars polishing pad and High gloss Polish. I started with 600 RPM do some passes and then do some more passes at 1000 RPM. I finished with one pas or two at 600 RPM. In the whole procedure I dod not use any pressure, just thw weight of the rotary. The result was some nasty holograms
most of swirls were gone (I said most not all :P:P) but holograms oh my god
I supposed that I could remove the holograms just by using a milder polish and the
meguiars finishing pad. SO once again the same polishing procedure but this time with Wax Finish and
meguiars 6.5 finishing pad.
After I primed the pad I used little product as you see in the photo...is it enough???
After polishing the results:
half and half
Everything looked better but not perfect.
Any suggestions? ( I do not have a pc to finish down and I can not buy one...I wait for the 230V version of UDM)
Also I was not able to speed up my rotary more than 1000rpm as the polish dry almost immediately.
And one prolbem that I face. Some times even in such a low speeds polish just dried out and leave me some nasty spots ( I remove them with some repolishing)
Finally my previous experience with rotary was with some crappy ebay pads and 1z paint polish (the green can). PP did not dry so quickly and it has so much lubricity. 1z pro series and
meguiars had a lot of drag.
