So last week I polished my black 2k Frontier for the first time with my PC. Well the paint came out way clearer and mirror like, however I only managed to remove the majority of the water spots and the oxidation. My truck is full of micromarring and fine to moderate scratches which I want to remove before I wax my truck. Alot of the scratches I can feel with my finger nails so im wondering if its possible to get these out with the PC. So basically Im looking for some tips and different products, if necessary, I can use to achieve better results on the paint defects. I appreciate any constructive feedback given. Also keep in mind that im not looking for perfection, I just want to remove the big stuff like the scratches. These are the steps I took and the products I used to polish my truck:
1. Washed truck w/ dish soap
2. Used
Clay magic to clay bar the whole truck
3. Used Megs [edit] #83 w/ Megs 6.5 in. cutting pad and wiped off residue w/ microfiber towel
4. Used Megs# 9 w/ 6.5 in. green polishing pad and wiped off residue w/ microfiber towel
Here are a couple bits of important info you guys should also know:
1. This is also my first time using the PC
2. I Used about a nickel sized amount of polish on every 2' x 2' section
3. I Ran the PC at speed 5 when polishing
4. I used a Megs 5 inch backing plate
5. The green pad I used was a generic one b/c the store didnt have a Megs Polishing pad
Here are some pics of how my hood turned out and some pics of the paint correction I need to do on my truck.
