Originally Posted by Danase They are not getting harder, you don't have to worry.
What products are you using? |
For areas that need more correction, I use
Meguiar's #83. If it doesn't need too much correction I go with
Meguiar's #80. I follow that up with Meguiar's #9 and then my final step is Meguiar's #21. I do everything with the white pads, except the 21 I put on with a black finishing pad. This is all on a
UDM, with the speed at 5 (except for the 21, I do that at speed 3)
One of the reasons I started this topic was because when I look at my black finish real close in direct sunlight it looks like it has just a little bit of a haziness to it. If I step back a few feet it looks awesome, so maybe I'm just being picky, but I just can't help but wonder if I'm leaving just a little bit of micromarring behind, even with using a polishing pad and #9 as my second last step. So I thought I'd see if perhaps the pads might be to blame for part of this. Otherwise, maybe I need to try another product as my second last step? (something like
Menzerna Micro Polish perhaps?) Or more likely, there is something wrong with my technique?
