Old 09-26-07, 11:42   #1 (permalink)
Doc Rice
doc-rice's Avatar
doc-rice is offline
doc-rice is on a distinguished road
Time saved with rotary vs. PC
I nudged this question into another thread but didn't get a full answer so I'm posting it again (as it was originally somewhat off-topic anyway).
I've done a few cars with the PC so far and each time it takes me 15 - 20 hours to go through the polishing stage. I'm either really slow or just deliberately careful (and I'm also working on hard clears in not-so-great condition). I might be doing a few more of my friends' cars and considering the amount of time I spend polishing, I'm thinking it might be worth jumping to a rotary to save time (practicing on a few junkyard pieces first). I can put down $200 for a rotary, and if I can save even a day or two's amount of work vs. the PC, it'd be worth it for me.
So to boil down the question: in general (with much estimation I'm sure) with all else being equal, how much time would one save when using the rotary on a given car, assuming equal amount of experience with the PC?
Old 09-26-07, 11:45   #2 (permalink)
Too Many Products
DieselMDX's Avatar
DieselMDX is offline
DieselMDX is on a distinguished road
Re: Time saved with rotary vs. PC
ALOT less that 15hrs!
I would say you can polish a car in about a 1/4 of the time BUT you have alot more of achance of ruining the paint
Put it this way I have a rotary and still use PC cause i dont have confidence in ti to use it on a customers car
2005 Graphite Pearl Honda Accord EX
Club: Flex Member
Old 09-26-07, 11:50   #3 (permalink)
Concourse d'Elegance
stiffdogg06's Avatar
stiffdogg06 is offline
stiffdogg06 is on a distinguished road
Send a message via AIM to stiffdogg06
Honestly, I could do a car in 8 hrs with the PC and get mediocre job. I can do a job on the rotary in 8 hours but basically have the car 99.99% defect free.
I think if you learn the rotary and the way the polishes break down on it. I think you will be able to speed up a remarkable amount and still getting better results. I believe its common since, if you LEARN the rotary the right way and learn to use it, you will get better results in a faster time than with the PC.
Turbo D Club Member #000001
Old 09-26-07, 11:58   #4 (permalink)
Anosmiac's Avatar
Anosmiac is offline
Anosmiac is on a distinguished road
I learned the rotary on boats. It started doing my father's 21 footer....then 23...then 32....then 31....then 40!!!! In between, I would use a DA at times, as we only had one rotary, one DA. This will never happen again!!! I now have a 21' Triton 205, my personal boat. I just did it the other day with a rotary. Understand, I "wax" this boat three times a year, but it still cuts my time drastically.
Rotary is the way to go, but it takes practice... and lots of it. If you have never really had any experience with a rotary, do what a lot of guys suggest. Go to a local junkyard, but a hood/door that is in bad shape, but reclaimable. Work on it an refine your techinique. Learn your different pad/product/rpm combinations. It is an ongoing process. And trust me (and most others), this is the right place to search for suggestions!!!
By the way, here is a pic of my boat:
Old 09-27-07, 05:40   #5 (permalink)
tomstin's Avatar
tomstin is offline
tomstin is on a distinguished road
I have a rotary and PC and find the rotory best for correction and the PC for finish work. The pads fit both machines, so no duplicate expense. There is an art to detailing a car that takes time to develop. The rotory takes practice and its easy to go overboard pretty quick. Find someone to give you a few lessons and the junk yard hood or trunk lid is a good test bed. The first detail or two, the rotory will probably not save you any time. But your speed will improve with practice and experience. But if you need a rotory a lot, then you're taking on a lot of dogs!
Old 09-27-07, 09:13   #6 (permalink)
0 to 60 in one paycheck!
SuperBee364's Avatar
SuperBee364 is offline
The amount of time it's taking you to do a complete polishing job with a PC sounds perfect to me; that's the same time range it was taking me, as well. Expect to cut the time in half, once you're proficient with a rotary. I can now do a three stage polishing job on a large car in the 8 to 10 hour range.
Old 09-27-07, 11:27   #7 (permalink)
I can't put a number on it, but using the rotary saves a *HUGE* amount of time when I do use it.
More importantly, it lets me get more correction done on very hard paint in the time I can/will spend. I could probably get the Audis 95% via PC/Cyclo, but I simply won't spend that kind of time (many hours per panel) on this stuff. A few hours by rotary actually *accomplishes* something significant.
On softer paint though, I don't need/use the rotary. I can do the Mazda MPV just fine with a PC/Cyclo and the time I'd save with the rotary would be offset by time spent taping and the danger of damaging the soft, thin paint. Even the PC has caused some issues on that thing (really crappy OE paintjob on that one) so it's plenty aggressive enough.
Guess it just depends on what you're working on.
Old 09-27-07, 12:27   #8 (permalink)
Doc Rice
doc-rice's Avatar
doc-rice is offline
I don't foresee working on an Audi anytime soon, but certainly VW. I'm assuming they have equivalent tough clear coats? I might be also working on a couple of '99 Ford Mustangs, but I'm not sure how the paint is on those. Hondas, on the other hand, I hear is soft / thin and I'll probably just use the PC on those.
Old 09-27-07, 12:40   #9 (permalink)
AFAIK VWs are usually about the same as Audis. I've heard that Fords are fairly soft but no first-hand experience.
Old 09-27-07, 09:51   #10 (permalink)
White lexus 23's Avatar
White lexus 23 is offline
White lexus 23 is on a distinguished road
Send a message via AIM to White lexus 23
i would have to say that its alot eaiser to correct with a rotary then it is with a PC. But the way i look at it is no matter which one your using its just how good you are with either and how much time it will actually take to correct and polish everything the way you want.
down here in colorful colorado!
Old 10-04-07, 04:58   #11 (permalink)
mhuie is offline
mhuie is on a distinguished road
I'm curious about rotary vs PC also, when you say 10+ hours, does that mean 10+ hours of actual PC on the car time? I have a PC but havent used it extensively yet.
BMW E34 530i
BMW E38 740i Sport
Old 10-04-07, 05:23   #12 (permalink)
keep_it_clean's Avatar
keep_it_clean is offline
keep_it_clean is on a distinguished road
how many steps or you doing? 15-20 hours just for polishing sounds like ALOT of time. a rotary would save you alot of yuor time. with all the new abrasives in the polishes you should only need to do a 2step polish. 3step for extreme correction. with a rotary should only take about 3hours for 2 step. and that is at the very most. i have done it.
as far as the money you have to spend oin a rotary. $200 will get you a nice one. go for the hitachi. i have seen them from $160-$180. it is a great machine. has i think 5year warranty,as long as you register it.
took out the rotary for the first time today.... toyotaguy Machine Polishing 9 09-07-06 05:12
Help me out... should I get a Rotary? whitejavaS500 Machine Polishing 2 07-27-06 03:04
1st time rotary questions? twopu Machine Polishing 4 04-16-05 10:55
Used my rotary for the first time today, not too happy JDookie Machine Polishing 58 04-12-05 07:44
The difference between orbital polishers and rotary buffers Mike Phillips Car Detailing Product Discussion 20 05-18-04 01:38
