By joining our FREE community you will be able to interact with others. Registration is fast, simple and absolutely free so please, join our community today. When you join, this box is replaced with our live chat! |
05-08-08, 10:11
#97 (permalink)
0 to 60 in one paycheck!
SuperBee364 is offline
Re: Question for PC users that switched to Rotary?
Yeah, I only put it on hand tight, but it ends up being very difficult to remove. I think it's cause it gets hot then cools down. My new 3403 sends alot of heat down the spindle. It gets too hot to touch, actually.
Originally Posted by Danase
05-08-08, 10:16
#98 (permalink)
Resident Schizo
Mindflux is offline
Ahhh.
Well that makes it difficult to switch pads if the adapter is scorching hot.
How's the 3403 otherwise?
08 GTI
dubdriver
Mixing is for hacks!
Quit lurking! You know who I mean.
05-08-08, 10:18
#99 (permalink)
Originally Posted by Mindflux
Ahhh.
I love it. So glad I got it instead of the 9227, especially when I'm doing vertical panels. It's so light.
Yeah, I've burned my thumb a few times on that adaptor when switching pads.
05-08-08, 10:18
#100 (permalink)
Resident Schizo
Mindflux is offline
Nice. I've got a Metabo so I'm not sure that having a 3403 would be anything but another sweet buffer in the arsenal.
Did you get yours from Phil?
08 GTI
dubdriver
05-08-08, 10:26
#101 (permalink)
I got it from Ranney. I wasn't aware of Phil's sale on them until I'd already ordered it from Pak Shak.
05-08-08, 10:32
#102 (permalink)
Resident Schizo
Mindflux is offline
Well it's a tossup anyway with the polishing pad included.
08 GTI
dubdriver
05-08-08, 10:54
#103 (permalink)
mystic04 is offline
Originally Posted by Rob Tomlin
I might get the hang of this after all.
Edit: bummer, it looks like Autogeek won't let me order single Edge 6" foam pads, they want me to buy the entire kit (5 pads) for $79.99. I only need 2 or 3 of their foam pads.
GO to Edge and buy them dhttp://www.edgepads.com/
04 cobra mystichrome
05-08-08, 11:00
#104 (permalink)
Resident Schizo
Mindflux is offline
08 GTI
dubdriver
05-08-08, 01:01
#105 (permalink)
From Hobby to Obsession
Denzil is offline
I guess you missed my previous post?
Oh by the way, this thread is now bookmarked. TONS of good information in this thread, hehe.
Devil Pad
Professional Automotive Detailing
05-08-08, 02:54
#106 (permalink)
Lotus Exige S
Rob Tomlin is offline
Rob, did you get the backing plate off yet? I've had a tough time getting my E2K adapter off every once in a while. Chanel Locks do the trick everytime.
Yep, got it off. The WD 40 may have helped *a little*, but I really had to yank on that SOB hard before I got it off.
Like I said, it was the original backing plate, and the Makita looks like it has been fairly well used, so it was stuck pretty good.
05-18-08, 02:44
#107 (permalink)
Lotus Exige S
I've played with my Rotary a bit more. Still trying to get everything down. I'm not sure if I am using too much polish.
How much polish (SIP) should I be using on a PFW pad? How much working time should I expect?
05-18-08, 05:29
#108 (permalink)
After the pad is primed, about four dots, each just a bit larger than a pea. I'm usually only able to get about three passes out of SIP and foamed wool. Occasionally four. Works out to be about 35 seconds or so. Working time on Menz polishes is really variable according to temp and humidity, though. SIP doesn't normally finish out really clear like most polishes do, either. It starts to flash before it goes clear (in the dry air where I'm at, at least). It still leaves a *very* nice finish, even if it's not clear when it's too dry to continue polishing.
With 106FF, you should have almost unlimited working time. There's no real point in working it after it goes clear and very oily looking, though. The abrasives are pretty much gone by then. I usually work 106 and 85RD for two minutes with foam, 1.5 minutes with white finishing wool.
