Autopia.org
Old 09-24-07, 09:45   #13 (permalink)
Doc Rice
doc-rice's Avatar
doc-rice is offline
doc-rice is on a distinguished road
Re: Question for PC users that switched to Rotary?
A question from a new PC user: in general, how much time is saved by using a rotary vs. a PC? I've detailed the equivalent of 3 vehicles (quite a lengthy process when you're talking about hard clear and paint that's never been cared for) and today I started thinking that my time is pretty important to me. If I'm going to be doing a few friends' cars, it might be worth it to just spend $200 on a rotary, practice a bit on some junkyard pieces, and save some time in the long run. If I can save even 2 or 3 days worth or work, I think it might be worth it.
Old 09-24-07, 10:35   #14 (permalink)
tod071 is offline
tod071 is on a distinguished road
Send a message via AIM to tod071
Learning how to use the rotary only adds to your experience in detailing. I don't think anyone replaces a PC/UDM with a rotary. Its an addition to the PC/UDM and cuts the time to correct drastically. It has cut my time in correcting some pretty bad jobs. I think learning the rotary will only make you better and faster at paint correction.
Old 09-25-07, 09:15   #15 (permalink)
Dewey, Buffet & Howe
JuneBug is offline
JuneBug is on a distinguished road
I've got a PC and a Makita. Unless I need to do some serious corrections, I'll use the PC with an yellow - orange pad. The polishes I use finish down LSP ready and I apply a wax with the blue pad and I'm done. If I use the rotary for the same process, I find that it's not as easy, I have to watch for trim and moldings, the actual time spent per panal is about the same and I can man-handle the PC in more places. Please note, that the cars I detail are daily drivers and beaters, the customers are not taking it to the car show and they and I are more concerned with keeping the clear coat as thick as possible. To them, a few stray scratches that you only see if you tilt you head under the lights at the gas station - well, they ain't a big deal.
Old 09-25-07, 12:51   #16 (permalink)
MikeWinLDS is offline
MikeWinLDS is on a distinguished road
I'd like to see what people have to say about going straight to rotary from nothing. I don't remember for sure, but I think Sean (G35Stilez) started out only with rotary, and he did incredible work. I don't know if he ever got a PC or even had problems with holograms or buffer trails that he would need a PC to even it out, but yea anyone else on here that started out with just the rotary? How hard is the learning curve straight from hand to rotary?
Old 09-25-07, 01:01   #17 (permalink)
michakaveli's Avatar
michakaveli is offline
michakaveli is on a distinguished road
Originally Posted by JDookie
... I would still rather grab my PC and/or Cyclo over the rotary any day.
You'll like the UDM.
Old 09-26-07, 05:07   #18 (permalink)
SpeedEuphoria is offline
SpeedEuphoria is on a distinguished road
just got a makita rotary, used my new UDM once. Its a lot more powerfull, the controll is slightly harder but you have to realize that its more important also. It you slip around or hang on a spot too long w/ a UDM, no big deal, w/ a rotary, well hope for the best(not meant to make people fearful). This is on a cutting step. The rotary seems to bring more shine IMO. I plan on using it on my daily driver that i've already gone over w/ the UDM, see if I can get to some of the scratches that were still there beause I didnt have more time.
Old 09-26-07, 07:22   #19 (permalink)
sneek's Avatar
sneek is offline
sneek is on a distinguished road
It isn't as easy to burn paint as most people think. Just get something to practice on.
Old 09-26-07, 08:33   #20 (permalink)
yeah just stay away from using the edge of the pad, when getting into the tight spots. Also wool is much more user friendly imo
Old 09-26-07, 08:46   #21 (permalink)
porta is offline
porta is on a distinguished road
Rotary is the only way for me when doing serious correction.
Old 09-26-07, 08:48   #22 (permalink)
Super Moderator
JDookie's Avatar
JDookie is offline
JDookie is on a distinguished road
Doesn't wool create more heat?
Old 09-26-07, 09:00   #23 (permalink)
ptaylor_9849's Avatar
ptaylor_9849 is offline
ptaylor_9849 is on a distinguished road
I think you've got your answer. If money is tight then buy a cheap Chicago Electric rotory for thirty bucks. Of all the detailing tools and products I own there are only two that I wouldn't go without. My rotory and my foam gun. My foam gun eliminates wash induced marring and my rotory provides a shine that my P/C never could. Check out some of the click and brags of Rydawg and RickRack. Then look at the top of the post where they describe how they achieved their awesome finishes. I guarantee that they used a rotory almost every time. I only use my P/C for two things now: applying waxes and removing an occasional hologram.
Patrick
Old 09-26-07, 09:24   #24 (permalink)
JuneBug is offline
Wool actually runs cooler than foam, but you will get buffer swirls or haze from wool if you're using a heavy cut compound. They're easy to correct with foam pad and a good polish.
Another pad w/ rotary question.... nosed_b18b Car Detailing 14 05-28-04 02:49
Question with rotary buffers? IntrstlarOvrdrv Car Detailing 2 04-14-04 07:12
Question for people who switched from Zaino jw Car Detailing 11 10-31-02 05:33
Question for Zaino Users jw Car Detailing 4 03-22-02 06:01
Question for Zaino users with dark colored cars that buff with cotton..... Intermezzo Car Detailing 19 03-11-02 10:37
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
