08-01-07, 02:54
#13 (permalink)
ZIN is offline
Join Date: Jul 2007 Posts: 29 | Re: Just ordered a PC, few questions Quote: |
Originally Posted by Maxima9169 almost three months. | OK, you will be fine enjoy | |
09-20-07, 08:59
#14 (permalink)
russde is offline
Join Date: Sep 2007 Location: Albuquerque, NM soon to be San Antonio, TX Posts: 19 | Re: Just ordered a PC, few questions Quote: |
Originally Posted by ben_r_ Yea I have been wondering this too... Is there a different counter weight we should be using with the 3.5" backing plate and a 4" pad? | Two folks have asked this question, and I followed along hoping for an answer too...anybody?
Ok, some more reading and I've answered my own question: there's only two counter weights, a 5" and a 6". Terrific.  | |
07-04-08, 11:14
#15 (permalink)
tonysoprano is offline
Join Date: Jun 2008 Posts: 2 | Re: Just ordered a PC, few questions OK folks, I've done multiple searches and read multiple threads, and I still can't find an answer. I just got my new PC and the starter kit included both the 5" and 6" counterweights. Acting on the advice from this board, I also picked up the Edge quick connect system and a handful of the double-sided 4" Cyclo pads. Using the 4" Cyclo pads, do I use the 5" or 6" counterweight, or should I just remove the counterweight altogether? | |
07-05-08, 07:12
#16 (permalink)
| | Street Rodder
Eliot Ness is offline
Join Date: Aug 2004 Location: Lexington, KY Posts: 3,130 | Re: Just ordered a PC, few questions Quote:
Originally Posted by tonysoprano OK folks, I've done multiple searches and read multiple threads, and I still can't find an answer. I just got my new PC and the starter kit included both the 5" and 6" counterweights. Acting on the advice from this board, I also picked up the Edge quick connect system and a handful of the double-sided 4" Cyclo pads. Using the 4" Cyclo pads, do I use the 5" or 6" counterweight, or should I just remove the counterweight altogether? | You can't remove the counterweight and operate the PC because the counterweight is what holds the spindle/bearing unit in place.
Some like using a 5" weight, some swear by the 6" weight, and some (like myself) don't really notice a difference. If you feel the PC has excessive vibration with the weight you're using then swap it out and see if it makes a difference: The Dual Action Counterweight 'Controversy' - Car Care Forums: Meguiar's Online | |
07-05-08, 10:40
#17 (permalink)
Join Date: Jun 2008 Posts: 2 | Re: Just ordered a PC, few questions Thanks, I appreciate the info! | |
07-05-08, 01:45
#18 (permalink)
drew.haynes is offline
Join Date: Jun 2006 Posts: 495 | Re: Just ordered a PC, few questions SSR1 has almost zero bite. Also, I PERSONALLY would get only 4" pads. The 5.5" and up work, but not nearly as well, and the 4" pads don't slow down the process. I've done entire cars with 4" pads. | |
07-05-08, 01:56
#19 (permalink)
Buegie is offline
Join Date: Jun 2008 Location: Litchfield County, CT Posts: 72 | Re: Just ordered a PC, few questions Quote:
Originally Posted by Eliot Ness You can't remove the counterweight and operate the PC because the counterweight is what holds the spindle/bearing unit in place. | Are you saying its not possible, or is it just a bad idea? I think I've run a PC w/ 4" pads and without a counterweight, seemed to reduce vibration by quite a bit. | |
07-05-08, 02:18
#20 (permalink)
detail1 is online now Join Date: Jun 2008 Posts: 64 | Re: Just ordered a PC, few questions Quote:
Originally Posted by drew.haynes SSR1 has almost zero bite. Also, I PERSONALLY would get only 4" pads. The 5.5" and up work, but not nearly as well, and the 4" pads don't slow down the process. I've done entire cars with 4" pads. | Can u elaborate on this? I have read that using a smaller diameter pad with a PC gives the PC more power.
Thanks
Frank | |
07-05-08, 07:03
#21 (permalink)
| | Street Rodder
Originally Posted by Buegie Are you saying its not possible, or is it just a bad idea?........... | It's a very bad idea because the counterweight is what holds the spindle/bearing unit in place. I guess technically you could do it, but you run the risk of the spindle/bearing unit and your pad flying off the PC.
The following thread will illustrate how the spindle/bearing unit is exposed and removed after taking off the counterweight. HOW TO: Replace bearings - w/pics - DetailCity.org - Auto Detailing Forum | |
07-06-08, 11:26
#22 (permalink)
| | Practical Perfectionist
Join Date: Sep 2002 Location: NE Ohio Posts: 20,437 | Re: Just ordered a PC, few questions Quote:
Originally Posted by Eliot Ness ..Some like using a 5" weight, some swear by the 6" weight, and some (like myself) don't really notice a difference... | I prefer the 6" counterweight with *all* sizes of pads. Note that the counterweight is designed around the use of a *single sheet* of sandpaper stuck to the backing plate (so the functional difference is between the weight of the two sizes of PC-brand backing plates, and that's not much of a difference). As best I can tell, even a small backing plate with a 4" pad (let alone when the pad's wet with product) weighs more than a larger backing plate with just a piece of sandpaper on it.
I've been using 6" weights exclusively on my PCs for years with no problems. And it might just be a coincidence, but when I used the 5" weight that came with my first PC, it needed rebuilt after only a few years of use.
And yeah, I *always* use 4" pads (or the 3.5" LC PFW) for correction. It simply works better for me than using larger pads. | |
07-07-08, 04:43
#23 (permalink)
9935annivgt is offline
Join Date: Apr 2007 Posts: 133 | Re: Just ordered a PC, few questions Edge 2000 system with the 4 inch pads except for your white and blue ones. | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 01:26. | | | |
