| ZCS:Should I have ZFX'd and done multiple coats of Z5 Thursday I polished my car with IP, then followed with Zaino PC, then ZAIO.
Normally I would've done ZFX/Z5 Pro X 3 after that. However, I understood that ZAIO eliminated the need for ZFX unless you were doing multiple coats in one day. I was running a little short on time this time.
I then used Z-CS for the first time, and I called it day with plans to use Z8 the next day.
Pre-CS, the car looked really awesome! After I applied CS, I didn't notice much of a difference. Honestly, it didn't look any better than Z5 Pro/Z8. Even after putting Z8 on top of the CS, I wasn't totally blown away like I was prepared to be. It looks really good, but the WOW factor is not there like I've seen on other cars on here.
Should I have gone for multiple coats? Where did I screw up, or did I?
I didn't get to drive the car after all this work because it was rainy and the car is not a daily driver. I haven't seen it out in the sun. I'm pretty obssesive so I've tried to not worry about it too much. I'll look the car over for hours if I don't watch myself. |
