Old 07-02-07, 06:33   #1 (permalink)
dmcphee07SI is offline
dmcphee07SI is on a distinguished road
do you have to clean your pads after every use?
do you have to clean LC pads after every use if you bag them in ziplocs & use the same product with them all the time?
Old 07-02-07, 06:37   #2 (permalink)
Not too old to learn.
RTexasF's Avatar
RTexasF is offline
RTexasF is on a distinguished road
Re: do you have to clean your pads after every use?
Yes The product will dry and turn the soft foam into sandpaper.
Old 07-03-07, 06:00   #3 (permalink)
B&D Detailing Owner
Jakerooni's Avatar
Jakerooni is offline
Jakerooni is on a distinguished road
Send a message via Yahoo to Jakerooni
You should clean them after the days is done but you absoultly MUST spur them between uses at the very very minimum. they will dry up and clog and like said basically turn into sandpaper. Why risk wrecked paint over something and basic as cleaning out a pad?
Old 07-03-07, 09:42   #4 (permalink)
Self Professed Knowitall
Grimm is offline
Grimm is on a distinguished road
If I can't clean them right away, I'll put them in a bucket of water and APC until I can.
Old 07-03-07, 09:53   #5 (permalink)
Come on! Fhqwhgads!!
Jngrbrdman's Avatar
Jngrbrdman is offline
Jngrbrdman is on a distinguished road
Send a message via AIM to Jngrbrdman Send a message via Yahoo to Jngrbrdman
I use Danase Foam Pad Cleaner before I put the pads away. I don't store them in zip loc bags or anything, but I do clean them out. If you don't then it just dusts all over the place when you use them again. Ask yourself this.... Do you clean your microfibers even though they buff the same product off every time? You have to clean the pads or else they will cause you problems.
...it should be Encouraged!
Old 07-03-07, 10:08   #6 (permalink)
Perfectionist
D&D Auto Detail's Avatar
D&D Auto Detail is offline
D&D Auto Detail is on a distinguished road
Send a message via AIM to D&D Auto Detail
You should clean them and dry ASAP. To try I just stick them on the 7424 and turn it up to speed 6. Water slings everywhere, so watch out.
D&D Auto Detailing
-Dan
Old 07-03-07, 10:13   #7 (permalink)
Dewey, Buffet & Howe
JuneBug is offline
JuneBug is on a distinguished road
Try putting them on a rotary and spin dry - better wear a rain coat (been there-done that).
Old 07-03-07, 10:19   #8 (permalink)
Jngrbrdman's Avatar
^^^ Those last two comments are sort of dangerous advice. If you spin a pad on a machine without it being pressed against the car then you are very likely going to damage your pad. Edge pads and velcro backed pads alike can be damaged that way. The loop part of the velcro can become unattached from the pad and basically destroy the pad. With Edge 2000 pads the disc inside can actually tear the foam. Spinning a wet pad at 6 on a PC is risking quite a bit. You can spin it at a much lower speed with less risk and still get all the water out. Shake them as much as you can first before you try that method.
Old 07-03-07, 10:24   #9 (permalink)
BMW335i's Avatar
BMW335i is offline
BMW335i is an unknown quantity at this point
WIll my MF be ruined permanently if I used AJT and let it sit on it for a few days? Would it be fine if I washed it?
Jonathan
Old 07-03-07, 10:32   #10 (permalink)
Jngrbrdman's Avatar
I would still suggest soaking it first and spinning a bit of it out. Washing it can do some good, but I've found that it wears the pads out faster. Spraying them with a pad cleaner and washing them out with the hose, or just soaking them for awhile, seems to work better than the washing machine.
Old 07-03-07, 09:09   #11 (permalink)
P.M.S. Adjuster
Jesstzn's Avatar
Jesstzn is offline
Jesstzn is on a distinguished road
I spin mine at 4 in a pail ... learned the hard way .. one came off and you think a Frizzbie goes good .. thank gawd my helpers dog went and fetched it ..
My Web Page & Detailing tips.
Old 07-04-07, 08:34   #12 (permalink)
Loves cars
99blackSE's Avatar
99blackSE is offline
99blackSE is on a distinguished road
I usually clean em up immediately after use, get a solution of pad cleaner and let em soak.
New Cyclo Dual Precision Pads Anthony Orosco Machine Polishing 27 02-21-07 05:22
how to clean LC foam pads? 99ITR_SC Car Detailing 13 07-09-04 08:49
how do you clean your PC pads?? blackntan Car Detailing 9 10-03-03 06:13
Simple Green to clean applicators and pads Spilchy Car Detailing Product Discussion 9 09-21-03 03:28
How do you clean up blackfire off of pads? phareous Car Detailing Product Discussion 4 07-21-03 08:03
