06-29-07, 10:55
JL6er is offline
Join Date: May 2006 Location: Edison, N.J. Posts: 85 | Having an issue... Hey guys. So Ive been working with the Makita now for a few hours....and it definitely is bringing up the shine on an old truck, but Im noticing that the machine keeps trying to move itself - in whatever direction it wants- its its almost uncontrollable. It doesn't matter what speed i am on...But I haven't passed 1500 rpm.
This issue isn't so much of a "hopping" like many complain about...that hopping action only seemed to occur if there was not enough product on the pad.
Anyways, I certainly havent burnt any paint (yet), but I have no idea about holograms, considering the truck is flat white and its cloudy as hell out....ugh
Anybody know what im talking about regarding the machine trying to move in all different directions and it being very difficult to control?? | |
06-29-07, 10:57
Danase is offline
Join Date: Jan 2006 Location: Michigan Posts: 2,946 | Re: Having an issue... What pads and size are you using?
06-29-07, 11:08
tod071 is offline
Join Date: Oct 2006 Location: Hawaii Posts: 513 | Re: Having an issue... Keep the machine parallel to your surface. Sounds like its not parallel and uneven, causing the jumping. For me, most times the butt needs to be lifted. And yes, do make sure your pad has enough polish. Try spritzing it as well. | |
06-29-07, 12:00
tomstin is offline
Join Date: Apr 2003 Location: Wake Forest, NC Posts: 154 | Re: Having an issue... What works for me is to shift the pressure slightly to the 12 - 3 o'clock position. That seems to make it easier for me to control where it goes versus a mind of it's own. Give that a shot. | |
06-29-07, 12:59
JL6er is offline
Join Date: May 2006 Location: Edison, N.J. Posts: 85 | Re: Having an issue... Thanks, tomstin, i'll attempt the 12-3 o'clock position.
Also, when polishing, do you guys always use that "Arc" method of motion or is it ok to move the polisher in different directions.
Because I know with my PC, I generally keep it moving in up and down motions, but often times, I just go all over the area in lots of other different paths without any problem. Since rotary is much different, I dont know if that even smart to attempt... | |
06-29-07, 01:01
JL6er is offline
Join Date: May 2006 Location: Edison, N.J. Posts: 85 | Re: Having an issue... Quote: |
Originally Posted by Danase What pads and size are you using? | Well, I *was* using the provided backing plate and a Meguiars 6 inch Red pad.
But I actually just received my new flexible backing plate, so im going to try that out next.
Do you think the rigid backing plate that the Makita came with may have contributed to this problem of mine? | |
06-29-07, 08:02
| | The Towel Man
WCD is offline
Join Date: Dec 2003 Posts: 506 | Re: Having an issue... I used to think that hopping was caused by too little product, but after attending Auto Int's program, it was too MUCH product that caused this--I know exactly what you are talking about. I never go above 1250 RPMs and move in a slow up and down and then across and sometimes a third motion diagnal. The last time I polished with my Makita I used much less product and it moved so much better across the paint..try a spot. Also, make sure yo are cleaning the pad about every 2-3 applications- AutoInt stressed that many guys think they can polish the entire car because it's the same pad and product, but even the pads get dirty quickly so run it with a brush that will release the dried product sending a dust cloud out in front of you- works fast and well.
Good luck, Rob | |
06-29-07, 08:18
Dent's & Details is offline
Join Date: Jan 2005 Location: San Antonio Tx Posts: 734 | Re: Having an issue... You said that it was an old truck. If it is a Single Stage paint it will be very griping.
If your pulling color off the car it's SS.
This will cause excess pulling and your buffer will be harder to control.
Why would you use a Wizard to fix a dent?
Just call Your Dent Guy | |
06-29-07, 08:48
| | BANNED FOR SPAMMING
SVR is offline
Join Date: Dec 2002 Location: South Australia Posts: 2,465 | Re: Having an issue... Yesterday I managed to do a 2 by 2 ft panel with one pea sized drop of blackfire 106FF
that's amazing. I was using three or four | |
06-30-07, 04:57
JL6er is offline
Originally Posted by Dent's & Details You said that it was an old truck. If it is a Single Stage paint it will be very griping.
This will cause excess pulling and your buffer will be harder to control. | hmmm...this could very well be the explanation.
It is an old truck. And the flat, white, SS paint probably isn't helping matters much.
Thanks for that insight...makes sense. | |
06-30-07, 07:04
Mo1nk is offline
Join Date: Apr 2007 Posts: 12 | Re: Having an issue... Quote: |
Thanks for that insight...makes sense. | Have you ever used a floor polisher? Keep it flat, and let it float. What the poster said about too much downward pressure on the handle is a very common unintended initial tendency. And try to move it around with your upper body. Don't try to force it around with your hands.
Also, just curious, did you clay this car first? | |
06-30-07, 04:39
JL6er is offline
Join Date: May 2006 Location: Edison, N.J. Posts: 85 | Re: Having an issue... No, the truck was not clayed, and it was definitely in some pretty bad shape. But it actually came up pretty nicely. | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 12:45. | | | |
