Old 06-10-07, 08:49   #1 (permalink)
tarheels12386 is offline
And I thought the Portercable would be easy to use. I need help!
Alright well I went out and bought the porter cable 7424 and :
-2 orange pads via LC
-2 white pads via LC
-2 Blue pads via LC
-1 yellow pad via LC
- OP and OC
- XMT360
- Poorboys wax
So today I clayed the car and then went at it for my first time with the pc. Well it was not as all the reading seemed to make it. I lubed my pad with a QD and then put a dime size amount of the xmt360 on the pad. I then spread the wax on the paint with the pc off, then turn to three to get the xmt worked in for about a min then up to six till it is gone. One problem I am having it seems like it is hazing away before I turn to speed six. I then changed it up a bit and spreaded at speed one and then worked in at four then up to six. That worked a little better but not great. It also seems like I have to use a lot of the xmt on the pad to see it on the paint. I have a white car so it is hard to see in the first place. Why would I have to be using so much product and it disapear so quickly?
I did half the car with it then stopped because it just didnt seem like it was working out to well. I was doing this outside, and it was an overcast day with 80 degree temps.
Old 06-10-07, 09:15   #2 (permalink)
I love my Makita
kleraudio's Avatar
kleraudio is offline
Contact: Send a message via AIM to kleraudio Send a message via Yahoo to kleraudio
Re: And I thought the Portercable would be easy to use. I need help!
hmmm, I think you were overworking the 360. It is an all in one type product, I would say speed 5 would be good just starting out. Its VERY VERY hard to see on light colored paint. I made the mistake my first time using and applied WAY to much on my silver truck.
You basically want to work it until it dissapears, maybe next time lighten up the pressure on the PC and work it a little faster than you would a polish. You dont need all the pressure and crawling arm movement with this product.
OP and OC are a different story.
Jim
2004 Dodge Dakota SXT
Currently Wearing: Scottwax's Famous Pink Moose, JW AJT, JW AG
Mobil 1 Fully Synthetic Oil (What a difference!)
Old 06-10-07, 10:48   #3 (permalink)
Detailer in training
rkf76's Avatar
rkf76 is offline
Contact: Send a message via Yahoo to rkf76
First of all, what pad were you using? Secondly, hazing is what happens when wax residue dries, it's the film that's leftover. I can't imagine having to work 360 on speed 6, seems like overkill, especially considering how fast it breaks down. I'd say 4-5 max.
I <3 Hi-Temp
Old 06-10-07, 11:28   #4 (permalink)
BigAl3 is offline
agreed with the fellas, 4-5 tops on the all-in-ones/cleaner wax's...
Old 06-11-07, 12:07   #5 (permalink)
I am using the white pad. How much of the product should I be using per how many feet?
So speed 4 max?
Old 06-11-07, 07:56   #6 (permalink)
rkf76's Avatar
rkf76 is offline
So speed 4 max?
white pad is good. Use a quarter sized drop on the first panel or two, then once the pad is loaded you won't have to use as much, maybe a nickel or dime sized drop. As a general rule, always work a 2x2 area. You may be able to increase that as you become more familiar with the machine and products, but for the most part staying at about that will save you alot of time and frustration.
360 does melt into the paint pretty quickly so it's all about adapting to the characteristics of your material, not trying to get your material to adapt to you. One thing I noticed is that you didn't make any mention of how the car looked before 360 or after.
I <3 Hi-Temp
