| Re: buying my first detailing machine! Cyclo, the easiest running, smoothest running orbital type detailing machine you will encounter! Not cheap, but quality never is. Has 2, 4 " heads that can be turned sideways/whatever to get into the majority of places, be it small or whatever.
At least 5 times easier to use than the PC, won't shake you to death and leave your hands feeling like you've been attached to a chain/buzz saw, Cheaper pads, although you do need 2 (2 heads).
If you are seriously considering a tool (orbital type) this is the best there is!
Changeling
When I say expensive it is sort of a relative thing, you will spend probably $100.00 more for a cyclo than a PC, while searching the Internet for deals. Easier on pads/wallet Legiondary rugedness and the best customer service in the world!
The best analogy I can think of for the PC vs Cyclo would be the difference between 12:00 midnight and 12:00 . All the lights will come on and you will understand why the cyclo kicks donkeys !
Good luck, Changeling |
