Old 03-28-07, 01:15   #1 (permalink)
velobard's Avatar
velobard is offline
Metabo questions
I know the Metabo uses a 1-6 speed dial like the PC. Does anyone know what speeds the numbers translate to?
Also, what speeds do you run the Metabo at? Do you run slower speeds for extended periods of time? I've heard the cooling fan depends on the motor running faster in order to work well.
Old 03-28-07, 01:38   #2 (permalink)
Totoland Mach's Avatar
Totoland Mach is offline
Contact: Send a message via Yahoo to Totoland Mach
Re: Metabo questions
I think the 3 setting is approx. 1,500 rpm (so I've been told). That's where I use mine at 95% of the time. I'll slow it down for wool pads if I need a lot of paint correction.
Totoland Mach
2003 Mustang Mach 1
Old 03-28-07, 01:42   #3 (permalink)
Empty My Wallet
crew219's Avatar
crew219 is offline
Taken from:
Porter cable 7428 speed
Dave
Old 03-28-07, 01:50   #4 (permalink)
velobard's Avatar
velobard is offline
Originally Posted by crew219
Taken from:
Dave
This looks like it's probably pretty close, the the Metabo everyone here talks about is the PE 12-175.
I'd still like to hear whether anyone has problems running it at lower speeds.
Old 03-28-07, 01:51   #5 (permalink)
Hart's Auto Detailing
Whitethunder46's Avatar
Whitethunder46 is offline
Contact: Send a message via AIM to Whitethunder46
Does the faster the speed break down the polish better? Is there a certain speed that should be used with say a compound vs. a fine polish?
Old 03-28-07, 01:58   #6 (permalink)
JohnZ3MC's Avatar
JohnZ3MC is offline
1 = 700
2 = 1100
3 = 1500
4 = 1800
5 = 2000
6 = 2200
The dial is infinitely variable and the number/speed values are on a silver label on the right hand side of the housing so you don't have to memorize or refer to any manuals.
edit: The above figures come from the newest Metabo model, the #12-175.
-John C.
Old 03-28-07, 02:04   #7 (permalink)
velobard's Avatar
velobard is offline
Originally Posted by JohnZ3MC
1 = 700
2 = 1100
3 = 1500
4 = 1800
5 = 2000
6 = 2200
This appears to be close to the curve represented in the graph above rather than a linear progression.
Old 03-28-07, 05:08   #8 (permalink)
Whitethunder46- Most products will break down at any speed (at least the products I use) but higher speeds generally make for more aggressive work and are thus mostly used for major correction. Lower speeds are more gentle and are usually used for finer/final polishing operations.
There are a few weird situations like 1z polishes where high speeds (or even "normal for rotaries" speeds are too fast and break the abrasives down *too fast* for them to do the most effective correction, but those oddballs are very uncommon; 1z is the only product like that that I ever use.
No problems here, not that I've used it all that much so far.
Old 03-28-07, 08:45   #9 (permalink)
noooorb is offline
Does anyone know the speed settings and the corresponding rpm speeds for the Harbor Freight Rotary (yes the $30 one )
