Old 03-25-07, 05:29   #1 (permalink)
Fobia is offline
Fobia is on a distinguished road
cannot remove swirl marks!!!
I've tried 3m perfect it 1500 compound.. with a foam compounding pad and hooked wool pad!! via rotary 1500rpm.!!!
its on a black jetta!
there ice scraper marks uck its making me mad!!!.
will update pics soon.
Old 03-25-07, 05:41   #2 (permalink)
HenrikP's Avatar
HenrikP is offline
HenrikP is an unknown quantity at this point
Re: cannot remove swirl marks!!!
I think we need to see some pictures to define your problem first. Are the "swirls" from the brush or the actual scraper?
Learning How To Detail the Eco-Friendly Way
Old 03-25-07, 05:51   #3 (permalink)
Accumulator will become famous soon enoughAccumulator will become famous soon enough
Fobia- As I learned the hard way on my M3, sometimes you oughta wetsand. My painter told me to do that but *NO* I had to stick with the rotary...should've listened to him.
Noting that some stuff is just too deep to be safely removed, maybe you oughta hit it with some Meguiar's Unigrit, say the 3000. Just enough to take the sheen off the paint, don't get carried away Then see what it looks like after a pass with the rotary.
Old 03-25-07, 09:57   #4 (permalink)
Fobia is offline
check it out... i hate 3m. and im kinda a noob with a rotary!.. but this car was just horrible.. i was leaving trails everywhere!!!!! tips well appreciated.
i moved the pad slowy at 1500 rpms on 3m foam compounding pad with 1500 grit compound this is what i got!!!
no swirl correction... possibly making the paint worse.. because of the trails. good thing it was 't a costumer and just a friend.. but i let the pad glide across buffed till it was clear. and used slow passes.
hood
Old 03-26-07, 02:08   #5 (permalink)
porta is offline
porta is on a distinguished road
Buffer swirls from hell
Try another compound and pad combo.
Old 03-26-07, 05:14   #6 (permalink)
SVR
BANNED FOR SPAMMING
SVR's Avatar
SVR is offline
SVR has a little shameless behaviour in the past
It is best to move away from 3M. I bet that prima swirl, menzerna IP and FP (106 or RD) would take care of them and give you a great finish
Try a light cut pad first. Move up to medium cut if needed.
If using medium cut pad, return to light cut and follow with polishing and soft polish and finishing pad.
Old 03-26-07, 06:00   #7 (permalink)
WCD
The Towel Man
WCD is offline
WCD is on a distinguished road
If you were using a cutting product then you will put swirls into the paint, but it should also help with scratches. A polish should fix the swirls. I never go above 1400 rpms and prefer 1200 with a lambswool pad on clears. I did a test a few weeks ago with foam vs. the lambswool. After only 3 passes the temp on the paint was 115 with lambswool and 146 with foam. Heat might be aiding to your frustration. That said, do you know how much clear you are working with? The car we did had been detailed and buffed so many times that the clear was thin. We could not remove some of the fine scratches. Remove more than .3 of the clear and there is going to be trouble. ETG's (paint thickness gauges) aren't cheap, but a great tool to have.
Rob Regan
Old 03-26-07, 10:25   #8 (permalink)
Fobia is offline
yeah im stumped.
i went back with a micro glaze and a more of a finishing pad at 900 rpms.. but the glaze seeemed to still be leaving trails.!!
more opinions welcome
Old 03-26-07, 11:05   #9 (permalink)
Neat Freak
audicoupej's Avatar
audicoupej is offline
audicoupej is on a distinguished road
Send a message via AIM to audicoupej
I use HT EC and OP 50/50 with a yellow @1500-1900 to cut most VW/Audi clear then finish out with OP with a white LC pad @1100-1400.
]ohn
JEMM Automotive Detailing
Old 03-26-07, 11:50   #10 (permalink)
Fobia- That pad/product combo sure isn't working for you! Rather than try to "master" it on somebody's car (as opposed to a scrap panel) I'd try something else.
I'd also try working smaller areas so you can see what's happening before you have a large "uh-oh" to correct.
I'm no rotary-Meister by any means, but the results you're getting are a lot scarier than what I get with 3M PI-III ECRC 05936 and that's a mighty aggressive product. Dunno just what's going wrong (too fast, too slow ) but something's not right.
Going from the 1500-grade compound to a finishing glaze seems like too big a jump anyhow. I'd get some milder compound and a medium polish and try to get things good enough to finish out with the PC.
Old 03-26-07, 12:43   #11 (permalink)
Changeling is offline
Changeling is on a distinguished road
Rob Regan
Hi WCD, I hope all is well.
What foam pad were you using in the test?
Changeling
Old 03-27-07, 04:06   #12 (permalink)
SVR
BANNED FOR SPAMMING
SVR's Avatar
SVR is offline
Today's products don't leave swirls in the paint. It must be your technique.
Ive never put swirling into a cars paint with any level of correction by machine.
Not even with powergloss.
Maybe 20 years ago or more it would as that stuff was nasty crap but today it's not a problem
The only thing you could do is hologramming
Remove swirl marks by hand fiveiron Car Detailing 3 08-10-06 01:04
Hello Black G35 With Swirl Marks Advice tonymontana Car Detailing 18 12-06-05 04:17
How does my washing technique induce swirl marks when my motion is side to side? Jeff_M Car Detailing 9 06-13-05 04:41
How to Remove Swirl Marks... Gonzo Car Detailing 12 11-14-03 11:58
Swirl Marks DavidB Car Detailing 26 06-12-03 04:32
