Old 03-15-07, 11:10   #1 (permalink)
05 TL/Navi/6-MT/A-Spec
Macruz19's Avatar
Macruz19 is offline
Contact: Send a message via AIM to Macruz19
Run PC on my clear bra?????
Ok, I have a clear bra on my car. Do you think it's safe to run my PC on it at a slow speed? I'm going to do my hood soon but I want my bumper with clear bra to look as great as the rest of my car using the PC.
In the past I have been using abrasives on my clear bra (BY HAND) to remove some scuffs and scratches. No harm by hand, but I wonder if it's safe to use a PC on it at low speeds. I was thinking of using Menz IP + orange pad + PC on my clear bra. It also states on my paper work that the clear bra (3m) the plasitc is similar to a clear coat. Anyways, hope someone can help me.
Converted over to ONR & now Lowes grout sponge. Protected by 3M clear bra, and one layer of Zaino is all you need!
Old 03-15-07, 01:49   #2 (permalink)
GOT PREP?
ebpcivicsi's Avatar
ebpcivicsi is offline
Re: Run PC on my clear bra?????
I install PPF and only use OCW on it. When I am detailing a car with PPF, I tape it off and do not polish it. I am not really not sure what the PC would do, but I never risk it. Not sure that helps you at all...
A man with experience is not at the mercy of a man with an opinion....
Old 03-20-07, 07:32   #3 (permalink)
Macruz19's Avatar
Macruz19 is offline
Today I ran my PC on my clear bra. I used 6" and 4" CCS pad with Menz IP. Yes I used abrasive polish on it. Then I used a white pad with Z-14 & Z-PC. After I polished the clear bra, I then applied Z-AIO by PC. I used all speeds on the bra and nothing bad happened. The results made my clear bra.... well more "invisible."
After using the PC, I put 2 coats w/ ZFX of Z5p, and 1 x Z2p then did the final seal with my favorite Z-CS.
That 3M clear bra is tough, but it does scratch easy but I was able to buff it out. I'm happy with the results and my clear bra is clean and better than new!
So, if anyone has a 3M clear bra and a PC. I know there's different clear bras out there, but I'm sure that it's very safe to use the PC on clear bra
Old 03-20-07, 08:33   #4 (permalink)
YankeeFan is offline
I was told by X-Pel I could use a PC but use a polish with very limited abrasive. He also mentioned that they have found a cloth with a lot of rubbing alcohol gets out swirls too. Not much pressure is needed. Never tried either, will do it once it's warm here in Philly.
Howard
Old 03-20-07, 09:03   #5 (permalink)
Roger V's Avatar
Roger V is offline
Contact: Send a message via AIM to Roger V
I clayed mine and followed it with OP on a white LC pad with no problems. Helped with the yellowing. The porous material of the clear bra takes in a bunch of contaminants and the clay helped removed a lot of them.
Old 03-20-07, 09:20   #6 (permalink)
Macruz19's Avatar
Macruz19 is offline
Yup, I clay mine often. Got lots of dirt off today.
Old 03-20-07, 09:21   #7 (permalink)
The Swirlmallows
klnyc's Avatar
klnyc is offline
Contact: Send a message via AIM to klnyc
I use PC on my 3m CB w/only AIO on a white pad thou. I set to 3500 OPM.
Extra coat?
Ken
Old 03-21-07, 05:35   #8 (permalink)
Macruz19's Avatar
Macruz19 is offline
Yeah, the clear bra has a similiar clear coat like the cars paint.
Old 03-21-07, 08:45   #9 (permalink)
wannafbody is offline
why not use a plastic polish?
2000 WS6 TA NBM
Old 03-21-07, 01:10   #10 (permalink)
Macruz19's Avatar
Macruz19 is offline
I also used a plastic polish as I stated above (Z-14).
Old 03-22-07, 12:53   #11 (permalink)
Danforz is offline
What speed did you run the PC at?
Old 03-22-07, 05:24   #12 (permalink)
Macruz19's Avatar
Macruz19 is offline
First I started out with 3 to avoid splatter, then I eventually moved to 6 with no problems. It turns out that my clear bra is actually more clear.
Keep in mine, this was the 3rd time I used a PC. 1st time on the hood and bumper.
I love my new toy!
