Old 03-13-07, 06:18   #1 (permalink)
05 TL/Navi/6-MT/A-Spec
Macruz19's Avatar
Macruz19 is offline
Macruz19 is on a distinguished road
Send a message via AIM to Macruz19
Got my PC, but can't get rid of all swirls (pics)
Just got my PC 7336 today so I wanted to try it out. I just did one part of my car which was one side of the roof of my car. I had some swirls I wanted to take care of so I used Menz IP with the orange pad first. I was so scared to use speed 6 since I never tried but then I just went ahead. Nothing to it. I stopped and buffed it off. Looked better but the deeper swirls were still there. I then switched to the Yellow pad and used Menz IP again. This time it took a little more of the swirls, but still there ** I did not apply pressure on the PC **
So I then tried the same procedure with the Yellow pad. Still there. I stopped and then used a white pad for Z-PC. That made my paint even more shiny. I then used Z-AIO by machine for the first time, topped it off with 2 coats of Z-5pro w/ZFX, and 1 x Z-2. I then used Z-CS to final seal the section I worked on. Here are some pics.
My question to the veterans and pros. Do I need a better pad/polish/or more pressure and time to make my car almost flawless without using a rotary machine? This was the first time and to me, I think it was 60% better. I did make that one part of my car even more shiny! Thanks for the help and advice!
Converted over to ONR & now Lowes grout sponge. Protected by 3M clear bra, Z-AIO, Z-5p, Z-CS & topped with Z-8
Old 03-13-07, 06:30   #2 (permalink)
SilverSeven's Avatar
SilverSeven is offline
SilverSeven is on a distinguished road
Re: Got my PC, but can't get rid of all swirls (pics)
Hi Macruz19, the thing with the PC is u need to apply pressure bout 10 - 15 lbs and slow arm speed. Don't be afraid of the PC, it's a very gentle machine. It would not burn through the paint.... And slowly work the product (cleaner polish) till it nearly dry. But not completely dry. Its all in the technique. Don't worry the PC is far less as aggressive like the Rotary.
Oh one more thing remember to turn down the speed when use the PC for waxing. Waxing u just need speed either 3 or 4.
By the way..... Nice work.
Old 03-13-07, 07:34   #3 (permalink)
Macruz19's Avatar
Macruz19 is offline
Thanks for props and tip...
anyone else with a solution? Thanks again.
Old 03-13-07, 08:13   #4 (permalink)
I love my Makita
kleraudio's Avatar
kleraudio is offline
kleraudio is on a distinguished road
Send a message via AIM to kleraudio Send a message via Yahoo to kleraudio
I have found that you have to work really slow in order to clean up swirls. also make sure that you work the polish till it breaks down. i use PB SSR 2.5 and I work it until it literally starts dusting a little bit. takes a while but its worth it. just know your polishes and experiment it took me two cars to get the hang of it, now its a breeze.
Jim
Old 03-13-07, 08:18   #5 (permalink)
Wetwerks's Avatar
Wetwerks is offline
Wetwerks is on a distinguished road
Let me first start off by saying that from the looks of your pics you've done some good work there.
Now then, as you may or may not know, there is only so much you are going to be able to accomplish with the PC. I think most everyone on the forum would agree that there comes a time when you just have to tell yourself "that's as good as I can get it with the tools in my arsenal". (Believe me, as anal as my partner and I are we are CONSTANTLY dis-satisfied. Whether it be due to product selection or hardness of the clearcoat. In our eyes, it's NEVER good enough. )
The other thing I noticed is that from the pic of the pads you have over the bucket, they look to be fairly large. It may just be the close-up of the picture but if you are using a pad any larger than 7 to 7-1/2" on a 5" or 6" backer plate, you may be having problems with the area actually getting "worked". Most of the work is being done directly beneath the backer-plate and maybe 1/2" to 1" outside of that as this is where most of the pressure is being applied. The best way I can put it is that if you want to use "flat" pads, I'd stick with the ones that are the EXACT size of your backer-plate. If you wanted to use variable contact pads (preferably the "curved edge" type) which are a bit more versitile and can get into smaller areas, you can go up to 7-1/2" on a 6" backer and be fine. In fact, I'd recommend a 7-1/2" over a 6-1/2". As you roll the machine on it's edge you also will be moving the pressure-point and you'll still have most of the pressure right above your work area.
If you've never seen the curved edge VC pads follow this link:
Lake Country Manufacturing Inc.-Products - Curved Edge Variable Contact (VC) Foam Pads
Don't forget about The EDGE 2000 system also. Fine pads in their own right.
Hope this helps some. Good luck!
Jason
Co-Owner/Tech. Advisor
Wet Werks Auto Salon
Austin, TX.
Old 03-13-07, 08:27   #6 (permalink)
Macruz19's Avatar
Macruz19 is offline
Jason
Austin, TX.
Thanks!! My pads are 6 1/2. I'll check out the pads on the link you sent me. For now, I'll try to take my time with this one.
Old 03-14-07, 10:32   #7 (permalink)
Clean Car = Happy Car
SVTContour's Avatar
SVTContour is offline
SVTContour is on a distinguished road
I'm not a pro, but from experience I would echo the post about making slow passes with *some* pressure, but not too much pressure so that the dual action rotation of the PC stops.
The other thing is to work a panel or half panel, remove residue and check work, and then do that section a second time. I've had that work for me as well.
Other than that, obviously you could step up to a more abrasive compound. Somewhere there's a post with most popular polishes listed from most to least abrasive.
Old 03-14-07, 10:53   #8 (permalink)
Macruz19- I agree that you already have things looking nice. Going to the next level might be a lot of work and I often think that people get some unrealistic expectations from being around this website. Heh heh, yeah, that's more of my Autopian Heresy
I use a fair bit of pressure when doing correction via PC. The 6.5" pads tend to *not* lend themselves to this very well- the friction causes the PC to "bog down" and merely "jiggle". So for any significant correction I use 4" pads. These allow you to apply more pressure and they just generally behave far more aggressively. So I'd get a small backing plate and some 4" pads and see how that works out. But that's *if* you're truly unhappy with how it looks now Don't go by what other people post here, go by what it looks like to you and how you feel about it.
Old 03-14-07, 11:30   #9 (permalink)
Macruz19's Avatar
Macruz19 is offline
That's what I'm talkin about! I want to be flawless
Old 03-14-07, 07:10   #10 (permalink)
I agree with Accumulator's view. Sometime we set too high expectations from the PC, the paint, the products & from ourself. Its not impossible to get a more swirl free paint but you must understand that it will come back too. It was there in the first place rite. From daily wear & tear condition of the world. For me I usually will be happy to get rid of 70 - 80 % of the swirls. It will just have some light marring & some deeper scratches on the paint. Since this is my work car & not a show car, I can live with some light marring. Even if the paint is flawless. After 6 months down the line, some swirls will be back again. Coz by washing, dirt/sand from driving on the highway behind a lorry carrying sand & every day wear & tear. This world is not perfect too. This world is getting worse every day, month & year. No one care about de-swirling the world or polishing up it too a shine back rite. We can only do so much? I too was looking for a perfect swirl free paint. But after finding Autopia's forum and couple of months reading & reading. I finally understand & try to look for a balance in life & in the pursue of a balance 'flawless' show car shine.
And the light marring that is left there also gives me a piece of mind that I didn't cut away too much clear coat in my process to find the ultimate shine.... Hehehe. Thank u.
Old 03-14-07, 07:17   #11 (permalink)
Newjack McZillion Q's
thesacrifice is offline
thesacrifice is on a distinguished road
flawless? better buy a second daily driver and get a rotary for your garage queen
me: Seafoam? what's that gf: I bet it's something new and cool and you're going to want it! me: why do you say that?
gf: cause you want everything
Old 03-15-07, 10:02   #12 (permalink)
Macruz19's Avatar
Macruz19 is offline
I just ordered a set of CCS pads 4" with the backing plate. I should get it by tomorrow so I can work on some of the deeper swirls this weekend. I can't wait to have me some fun!
PC not cutting out all of the swirls on a Vette, PICS!! 604_Coast Machine Polishing 26 08-06-06 06:56
1953 Ford F100 50th AE + Crazy garage pics mcnab Click & Brag 3 07-17-06 08:29
Car swirls easily, are they in clear coat? Sad, little man Car Detailing 10 10-29-05 06:54
Can't get rid of the swirls UnsanePyro Machine Polishing 24 06-14-05 08:48
swirls aren't really gone tuffluck Car Detailing 33 05-11-04 09:24
