03-12-07, 05:26
| | perpetually waxing off
CelicaLover is offline
Join Date: Jul 2006 Location: Sarasota, Florida Posts: 187 | Makita Rotary Question I should be recieving my rotary on Friday or Saturday and I'm getting the Makita 9227CX3. I know it has variable speed setting and I believe that on 3 the speed is something like 1500. My question is if I wanted to polish at 1200 how would I know I"m at 1200? Do you just hold the trigger halfway down to achieve only 1200?
My second question is can I spur foam pads to clean them or should I just replace the pad when needed? How do I know when I need to change pads...? Any additional information is more then welcome.
TIA
Josh
Reason: Brain Fart
03-12-07, 05:31
Slickery is offline
Join Date: May 2006 Posts: 273 | Re: Makita Rotary Question Setting 1=600 rpm's 2=1200 rpm's 3 = 1800 rpms
Autopia Rocks | |
03-12-07, 05:33
| | South Florida Style
themightytimmah is offline
Join Date: May 2005 Location: Boca Raton (FAU) Posts: 3,200 | Re: Makita Rotary Question Its variable between 2 and 3... usually I run mine at 2.3 or 2.5 for finishing, 3.0 for polishing and 3.5 for boats/aluminum/surfaces that need a little hi-speed lovin.
03-12-07, 05:43
Join Date: Jul 2006 Location: Sarasota, Florida Posts: 187 | Re: Makita Rotary Question I thought autogeek on there little table said 3 is 1500 but o well. Timmah what do you mean by you run it at 2.3 that isn't an actual speed setting is it? you do that with the trigger? | |
03-12-07, 05:43
Slickery is offline
Join Date: May 2006 Posts: 273 | Re: Makita Rotary Question Sorry, I was off a little, 2=900 and 3 = 1500, and like MM says you can use variable speeds inbetween each setting. However, I usually always am at three except for spreading, and I never burned through paint.
Autopia Rocks | |
03-12-07, 05:51
Join Date: Jul 2006 Location: Sarasota, Florida Posts: 187 | Re: Makita Rotary Question Do you do the variable speed with the trigger though? | |
03-12-07, 05:53
| | 1981 Camaro Z28
BigJimZ28 is offline
Join Date: Mar 2006 Location: Levittown, Pa Posts: 2,690 | Re: Makita Rotary Question Quote: |
Originally Posted by CelicaLover Do you do the variable speed with the trigger though? | No the trigger is on/off, you can put the dial anywhere between the numbers | |
03-12-07, 05:55
| | South Florida Style
Join Date: May 2005 Location: Boca Raton (FAU) Posts: 3,200 | Re: Makita Rotary Question Nah, I only use the trigger for startup - ill feather it a bit to get the polish spread out, instead of changing the dial to 1 and then cranking it up to the desired RPM.
As for 2.3 - there are 3 clicks between 2 and 3, 2.3 is the first of em.
03-12-07, 06:13
Join Date: Jul 2006 Location: Sarasota, Florida Posts: 187 | Re: Makita Rotary Question Thanks Timmah that helped alot. Now to just convince my girlfriend that of course its perfectly safe (so I can use it on her car first) and think of a reason why I don't want the first time using it to be on my car  . | |
03-12-07, 06:44
ZoranC is offline
Join Date: Sep 2006 Posts: 2,003 | Re: Makita Rotary Question Quote: |
Originally Posted by CelicaLover Now to just convince my girlfriend that of course its perfectly safe (so I can use it on her car first) and think of a reason why I don't want the first time using it to be on my car  . | I see you want to be an ex-boyfriend.  | |
03-12-07, 07:04
Join Date: Jul 2006 Location: Sarasota, Florida Posts: 187 | Re: Makita Rotary Question Na,  she already agreed to let me try it on her car, but only after I'v practiced on my junk panel. | |
03-12-07, 09:00
| | BANNED FOR SPAMMING
SVR is offline
Join Date: Dec 2002 Location: South Australia Posts: 2,465 | Re: Makita Rotary Question I don't spur them, the get rinsed under the tap and I dig out the buildup with my nails
Then after I've finished a car, in the washing machine they go. Triple rinse after washing (on gentle setting) | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 05:14. | | | |
