11-13-06, 06:45
toyotaguy is offline
Join Date: Feb 2006 Location: orange county, ca Posts: 2,106 | rotary vs PC..pc wins???? I am not talking about which is better....but whats up with this....
situation: BLACK Ford Ranger, heavily swirled and scratched up!
products: excel pads, optimum polishes, hitachi rotray speed - 1500-1600, PC speed 6, yellow excel cutting pad
problem: My PC worked better and faster than the rotary....WHY???
I tried a section of the hood with both to compare....set myself a time limit of use/broken down product. I polished with the rotary until the OHC/yellow started to clear, then I polished with the PC with OHC/yellow from excel until I made about 12 overlapping passes until it went clear. The Pc results were about 5x better than the rotary. Can someone explain what I possibly was doing wrong?
__________________ enviousdetailing - When quality matters! | |
11-13-06, 07:45
| | buff THIS
paradigm is offline
Join Date: Jul 2006 Posts: 1,010 | Re: rotary vs PC..pc wins???? my guess is that the black was marring easily and the PC's less aggressive nature helped out this time?
92 Accord LX 5spd- Bordeaux Red
07 Lexus IS350 - Tungsten Pearl
11-13-06, 08:05
| | U Bring It - I Bling It
David Fermani is offline
Join Date: Aug 2004 Location: S. Florida Posts: 2,889 | Re: rotary vs PC..pc wins???? Quote: |
Originally Posted by paradigm my guess is that the black was marring easily and the PC's less aggressive nature helped out this time? | My guess too. Does the PC section look acceptable, or is it still in need of work?
__________________ The Perfection is in the Reflection | |
11-13-06, 08:06
DSVWGLI is offline
Join Date: Feb 2003 Location: Vancouver Island Canada Posts: 928 | Re: rotary vs PC..pc wins???? Very strange indeed. I am new to rotary use but have used the PC for about 3 years now. I have the Hitachi as well and IMO it is a lot easier to use and more than twice as fast, at getting rid of swirls, as the PC in all my tests on a hand full of cars. How fast did you move the Hitachi per inch? If you move it to fast you will not heat up the paint which lets you know that you are doing things correctly. The paint should be toasty warm when your done, if not slow down. I move the Hitachi about 3" per second when removing swirls. If you are doing this and the PC is faster than I don't understand whats happening.
2003 VW Jetta GLI ~Get your shine on~ | |
11-13-06, 08:25
Join Date: Feb 2006 Location: orange county, ca Posts: 2,106 | Re: rotary vs PC..pc wins???? both are still in need of work obviously....cutting pad and OHC....but I achieved much better results with the PC...
moved the PC about 1" per second - made about 12 passes before going clear
and the rotary about 5" per second - made about 5 passes before clear
11-13-06, 08:37
Join Date: Aug 2004 Location: S. Florida Posts: 2,889 | Re: rotary vs PC..pc wins???? You might be surprised with the depth difference after you glaze it. I'll bet the rotary cut through the finish deeper, thus swirling it up more, leaving you better results in the next step.
11-13-06, 08:46
DSVWGLI is offline
Join Date: Feb 2003 Location: Vancouver Island Canada Posts: 928 | Re: rotary vs PC..pc wins???? Quote: |
Originally Posted by toyotaguy both are still in need of work obviously....cutting pad and OHC....but I achieved much better results with the PC...
and the rotary about 5" per second - made about 5 passes before clear | Did you fell the surface to see if it was warm? 5" per second can sometimes be too fast, you really have to pay close attention, unlike a PC which you can almost do no wrong. Also I find a cutting pad with a rotary will leave swirls behind, and the PC leaves hazing, so that could have something to do with it.
11-13-06, 08:47
DSVWGLI is offline
Originally Posted by David Fermani You might be surprised with the depth difference after you glaze it. I'll bet the rotary cut through the finish deeper, thus swirling it up more, leaving you better results in the next step. | Absolutely.
11-13-06, 09:05
Join Date: Feb 2006 Location: orange county, ca Posts: 2,106 | Re: rotary vs PC..pc wins???? so i should have ran through the whole process to see the results??? compound, polish, glaze, canauba?
also, I tried OC on a orange via both....the PC didnt cut all right away, but the rotary did, but it also scratched and left behind more defects that were "new"
is there a general rule that a light polishing pad and a aggressive polish might work better than aggressive/aggressive???
11-13-06, 09:13
DSVWGLI is offline
Join Date: Feb 2003 Location: Vancouver Island Canada Posts: 928 | Re: rotary vs PC..pc wins???? I think you only have to use a cutting pad on really hard paints, the polishing pad will remove most swirls and leave a far better finish. On some paints you woun't need a finishing pad even.
11-13-06, 09:28
Join Date: Feb 2006 Location: orange county, ca Posts: 2,106 | Re: rotary vs PC..pc wins???? i'll keep that in mind...thanks
11-13-06, 09:41
| | Sir-Wax-A-Lot
01bluecls is offline
Join Date: Jun 2004 Location: Ashburn, VA Posts: 2,163 | Re: rotary vs PC..pc wins???? I started using the PC back in the day (about 2 years ago) and every since I got the hang of the rotary, my PC is collecting dust. Every once in a while I break the PC out to see what it can do on a vehicle im detailing and after a few passes I give up and go right back to the rotary. The rotary once you get used to it can produce a better finish and cut down working time.
__________________ Refined Detailing
Chris - Sole Proprietor | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 10:39. | | | |
