I am not getting sling but just followed
menzerna's directions on the bottle of a six inch line, then a few drops for every panel afterwards
OK anthony, I will try a nickel. Usually I will do the top half of a door in one hit so I doubt a nickel would be enough???
RPM's - 600 to start, up to 1000, third pass 1100 - 1300 (mostly 1200)
I dampen the pad with XMT because if I do not, as soon as I start the machine, I get all this dust flying everywhere from the dry pad and the product. It's like talcum powder on the panel
Obviously I am nothing compared to you anthony so thanks for the advice.
Yes I agree, I stay central.
My technique has been - go from right to left at 100 to 400 rpm and pick up the polish, then do the first pass with the handle of the machine vertical, then second pass I switch to
the other way , from top to bottom and repeat. It's always with the final pass that the machine gets funny.
In the last couple days I have not had any trouble so looking good from now on
Just cut down on my product usage
Wouldn't using a toothbrush or that PC wrench tear the foam pad or cut into it, leaving grooves
