11-08-06, 11:25
LandonZ is offline
Join Date: Oct 2006 Posts: 129 | im still not happy with my results! hey, I got my new white finishing pad in the mail and decided to give it a try. I used Griots #3 polish which is suppose to be a final, white pad and used speed 6..I used griots because I didnt have my menzerna yet. Now here are the pics from what my car looks like with flash from a camera.. But when my car is in the sun, im still seeing some marring? Looks to be caused by the polish? *this thread is not linked to my other thread about marring*. can someone maybe tell me what im doing wrong on my car? its looks so good in the pics but im just not happy in the sun!! I WANT a flawless finish
2002 Bright Rally Red Camaro SS | |
11-08-06, 11:32
Danase is offline
Join Date: Jan 2006 Location: Michigan Posts: 2,946 | What polisher are you using? You might want to look into a Cyclo if you are not using one already.
Also, try going over the car a few times with the #3 and the finishing pad. | |
11-08-06, 11:43
| | Self Professed Knowitall
Grimm is offline
Join Date: Aug 2006 Location: Muskegon, MI Posts: 749 | If you are seeing marring in the sun, it might help to take a picture of it in that light. Looks perfect in that shot. | |
11-08-06, 12:16
LandonZ is offline
Join Date: Oct 2006 Posts: 129 | i will take a pic of it..the weather has been bad lately..really overcast. I think i am going to do another buff with my white pad and menzerna one more time! Do you think that might fix it?
11-08-06, 04:14
jaycevs is offline
Join Date: May 2003 Location: Akron Ohio Posts: 24 | One thing is to make sure to go over it enough times as the polish will break down into a finer abrasive. Like the others I cant seemuch in the picture, it looks good. | |
11-08-06, 05:01
| | Newjack McZillion Q's
thesacrifice is offline
Join Date: Jul 2006 Posts: 976 | perhaps the marring left behind just cant be touched by a PC? Looks great in that photo. | |
11-08-06, 05:13
| | Beach Bum Detailer
Joshua312 is offline
Join Date: Aug 2005 Location: West Michigan Posts: 2,785 | If you have FPII from Menzerna coming, go over the finish in the sun at 1/2" per second and do a panel and see if it helps. Working in the garage sometimes doesn't help because you can do the whole car under halogen lighting then pull it out to see marring. I think that should work for you. I had the same problem last year, but slowing it down should help. Never used Griots 3 so that could be the problem as well, but you can't go wrong with FPII! From that shot right there, great job so far! | |
11-09-06, 07:04
LandonZ is offline
Join Date: Oct 2006 Posts: 129 | i do feel like I have done a great job with the swirls.. Ill give menzerna a try on about a 6 or so.. then pull it out into the sun.. thanks for the advice
11-09-06, 08:09
| | ~werd to yo mutha~
Way2SSlow is offline
Join Date: Mar 2005 Location: Alpharetta, GA Posts: 1,463 | From the pic, your car looks pretty freakin good. I wouldnt get flustered if you cant get the paint flawless because, 1) it's an 02. It's probably got a few miles on it, and has more than likely been exposed to environmental factors that may prevent you from attaining absolute perfection, and 2) If it's a daily driver and black in color, you will drive yourself crazy trying to get it perfect and keep it that way. Keep at it, if you think it could get better, but dont expect perfection......I have learned that from experience and now enjoy the time I spend detailing my black car a lot more than when I got P*SSED because it wasnt perfect.
94 Impala SS in the ONLY color
04 Ford Focus ZX3 in white (daily driver)
~werd to yo mutha~
Wade----- Gallery | |
11-09-06, 10:07
| | Practical Perfectionist
Join Date: Sep 2002 Location: NE Ohio Posts: 20,090 | Yeah, gotta watch that you don't develope unrealistic standards, which is easy to do if you spend enough time here
FWIW, the Griot's MP#3 is a *VERY* mild product, too mild to do any correction for me in most cases, even on soft lacquer. There's simply only so much it can do. The FPII will have a bit more cut, even though it's pretty mild stuff too.
Oh, and you could always drive yourself nuts by getting some lights that let you see the light marring inside the shop, like an incandescent work light  | |
11-09-06, 11:33
| | winnie the two
xinkid is offline
Join Date: May 2006 Location: Round Rock, TX Posts: 140 | I would say don't drive yourself crazy over very minor things that you can't really see if you are "appreciating the look of the car". If you want to have an easier time with the minor flaws, next time try something like a glaze that has concealing properties. I believe in hiding very minor flaws as long as I am satisfied with the final outcome. Think about how much more time you can spend enjoying the look of the car as opposed to fussing over things you missed.  | |
11-09-06, 07:57
toyotaguy is offline
Join Date: Feb 2006 Location: orange county, ca Posts: 2,106 | stop there, glaze it and seal it....black is almost never going to come out 100%...at least its very hard to get it even close to 100%, I only know a few who have some so close, but still, it looks marred upon 2" away
__________________ enviousdetailing - When quality matters! | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 10:18. | | | |
