| IP won't give any better of a finish than FPII on a finishing pad, infact it will finish down worse due to the difference in abrasiveness. Remove ALL defects before finishing, then use FPII on a polishing pad, work it in at speed 6. I ALWAYS get the best finish using FPII over other finishing polishes, but your finish will not look its best if +95% of the defects are removed. |
