Old 10-29-06, 08:26   #1 (permalink)
DSVWGLI's Avatar
DSVWGLI is offline
DSVWGLI is on a distinguished road
Tried to damage a car today with rotary
Well not really. Today I detailed my neighbor's old car, so I thought I would be a little more aggressive with the rotary. Some areas of the car the clear is flaking right off so he wasn't to worried about it. I used a 7.5" LC CE cutting pad with OHC @ 1700 rpms slow passes, no problem here. The paint got a little warm but not overly hot. So I thought I would try that on the edges and guess what, no problem there either. Now I went a little quicker on the edges because I would never go slow on edges any way. The one thing that did happen was the pin striping melted away when I turned the pad on edge over the pin striping and worked that area for about 5 seconds . I found that as long as you keep the buffer moving over pin striping you won't have a problem as I was using the cutting pad and OHC @ 1700 rpms on it with out incident. So I learned that you would really have to try to burn an edge to succeed. The paint on this car was almost 20 years old so the clear should be thinner and more susceptable to damage than newer paint.
2003 VW Jetta GLI
~Get your shine on~
Old 10-29-06, 10:59   #2 (permalink)
microfiber bed sheets!!!
fdizzle's Avatar
fdizzle is offline
fdizzle is an unknown quantity at this point
thats good to know, thanks for the update on your hitachi adventures . . . .gonna be detailing a black 330 convertable tomorrow . . . cant wait to demolish some defects . . .
"Nice wax job rook!" . . . . - Ramathorn
Old 10-30-06, 04:34   #3 (permalink)
Beach Bum Detailer
Joshua312's Avatar
Joshua312 is offline
Joshua312 is on a distinguished road
I think your findings only pertain to this vehicle. I don't think it's a safe assumption to make that it isn't easy to burn paint with a rotary.
Old 10-30-06, 05:31   #4 (permalink)
Waxophile Autojourno
Bence's Avatar
Bence is offline
Yes, agree. On some paints just a light touch is enough and a fine white line appears on the edge...
When I tried to burn some beater doors, I was surprised that the large flat areas could withstand the serious heat and the abrasion of HTEC @ 2200 with HEAVY, panel bending pressure, yet the edges were very sensitive and got burned in no time, with negligible pressure.
Old 10-30-06, 06:09   #5 (permalink)
wannafbody is offline
I burned an edge on my WS6 hood. Flat areas wasn't an issue
2000 WS6 TA NBM
Old 10-30-06, 06:26   #6 (permalink)
Sir-Wax-A-Lot
01bluecls's Avatar
01bluecls is offline
01bluecls is on a distinguished road
EDGES ARE VERY DANGEROUS! I have seen burned paint from cars that were previously detailed by someone else. The edges on certain paints are VERY THIN and would not recommend hitting those edges with the rotary. Like others have mentioned it depends on the paint and vehicle. Otherwise you burn the edges on a vehicle you may have one unhappy customer and a paint shop repair bill in front of you.
Refined Detailing
Chris - Sole Proprietor
Old 10-30-06, 06:28   #7 (permalink)
DSVWGLI's Avatar
DSVWGLI is offline
Thanks for the input on this as I have not done to many cars yet. On my VW I used a polishing pad @ 1100 with OP over edges with no problem and that paint is very soft. I guess if your working on an older vehicle with soft paint you could run into a problem, as you don't know how much clear is left. But to burn an edge don't you have to create heat to burn through the paint ? Because I never let the heat build up to much on the edges to do that, I kept a steady speed going to gaurd against that. More advice please.
2003 VW Jetta GLI
~Get your shine on~
Old 10-31-06, 03:52   #8 (permalink)
Bence's Avatar
Bence is offline
Paint can be so thin that you get a burn mark (white line) in a fraction of a second, with the slightest touch of the rotary. It will happen more likely with an aggressive pad, but we've seen damages with finishing pads too.
Old 11-01-06, 07:35   #9 (permalink)
Wool is cool!
gmblack3a's Avatar
gmblack3a is offline
When I use EC/OP with a yellow, orange or even a white LC VC pad I always tape edges and seams. When I use 106ff with a green P2 pad I remove the tape first, the green P2 is soft enough.
Bryan Burnworth
Peachstate Detail LLC
"Paint Polishing Perfection"
Atlanta Detailing
Old 11-01-06, 10:27   #10 (permalink)
DSVWGLI's Avatar
DSVWGLI is offline
So in these incidences are the edges that are being "burned" getting hot or is it the friction of the pad against the edge with out heat that is taking the paint off. If it is happening with out heat then it is not a burn then. If paint is so thin on an edge that just touching it with the rotary takes the paint off, then a PC on speed 6 with pressure and slow passes would as well don't you think? On the hundreds of cars I've done I've never burned an edge with the PC compounding @ speed 6 using slow passes. Your thoughts.
2003 VW Jetta GLI
~Get your shine on~
Old 11-01-06, 10:41   #11 (permalink)
StumpyDetailing is offline
StumpyDetailing is on a distinguished road
If my math is correct, at the outer edge of the pad (the one that will cause damage), a 6" pad has 1.5ft of distance per revolution, which @ 1000rpm travels at 17.04mph. Now, anything going 17mph that is touching the paint can EASILY do a lot of damage of concentrated on anything less than a few square inches.... An edge can easily be 1/8th of an inch area...
Heat can burn paint, friction can soften and smudge paint, or it can melt the foam pad onto the paint (thank god paint wasn't hurt!)
Old 11-01-06, 10:55   #12 (permalink)
DSVWGLI's Avatar
DSVWGLI is offline
So you also believe heat is the damaging factor here?
2003 VW Jetta GLI
~Get your shine on~
