10-07-06, 11:04
Kenney is offline
Cant Get Polish Out of Pads
I cant get the OP completely out of my foam pads. I put the pads in dawn overnight and then washed in the morning, but if I squeeze the foam, a little bit of OP comes out. Is there any method I should use? It is ok just to leave the OP in there? I guess I could remove all of it by hand, but that would be time consuming...
Thanks
10-07-06, 11:07
StumpyDetailing is offline
I put a few circles of Dawn on the pad, run under the hottest water you can stand, and knead the pad with your fingers until all of the soap is out... It might take 2 tries, but it works...
If it doesn't come out with that, then I wouldn't worry about it
10-07-06, 01:43
Brace1 is offline
XMT pad cleaner, can't beat that stuff
10-07-06, 05:21
Crazy for rotors
metal is offline
I've had the same problem on one of my polishing pads, OP really likes to stay in there.
10-07-06, 05:44
Omnipotent User
SHICKS is offline
I have the same problem with IW 845, RMG and #16. For the life of me I cannot get these products out. SSR1 Turned my white pads pink, but never left a residue behind.
I have a new handi grip foam applicator from sonus for #16, but how do I get the #16 out? Dawn worked a little, but did not get all of it out.
Steve
10-07-06, 11:35
BMWWW is offline
Steve
Yeah, a lot of products stain the pads for eternity, but as long as they don't leave any residue behind in the pads, the damage is purely asthetical-- not to worry!
10-08-06, 12:31
EdLancer is offline
Use dishwashing soap in warm water in a tub, do not use hot hot water as it deterioates the foam. Place the pad facing up and compress the pad with multiple and rapid compressions and all the product or dirt will be forced out, if not let sit for 30-60 minutes and compress again. Pad will come out cleaner the clean this way.
2003 Rio Red Mitsubishi Lancer
10-08-06, 08:14
Detailing Loudoun
brwill2005 is offline
OP can be tough to remove from pads. If you can get you hands on it, try laundry soap in bar form. Rub the bar directly on the pad, let it stand, and then rinse.
Brad Will- Owner
Reflections Auto Salon LLC
10-09-06, 12:37
microfiber bed sheets!!!
fdizzle is offline
Has anyone here tried the DP polishing pad rejuvinator - its a powder form (can find it on autogeek.net) I love it - gets klasse out like its water . . . xmt and other pinnacle products comes out easy aswell . .
"Nice wax job rook!" . . . . - Ramathorn
10-11-06, 06:25
Bluesbrekr is offline
+1 for the DP. The toughest product for me is UPP and the DP is great at removing it.
Klasse is not really hard to get out of pads because it's water based.
10-11-06, 07:55
MorBid is offline
Yeah OP can be a bear to rinse out. I've found that even dish soap struggles with it. I use Hi Temps Akrya as a paint cleaner and it can do double duty as a pad cleaner as well. I just mix some in a 5 gallon bucket of water and dump my pads in, work it through a little then let them sit for awhile before rinising them out in the sink.
My other polishes are all water based and come right out but I find I need to let the pads with Optimum in them soak a little longer.
MorBid
10-11-06, 09:24
Waxophile Autojourno
Bence is offline
Some product will be more forgiving when you let them dry and then wash out. However, there are some finicky ones that work just the opposite way.
