| Edge yellow vs Megs burgundy... on a rotary. I decided to day to reattempt to reduce lots of etching on my hood. I first tried the Megs burgundy pad with OHC as many feel it's a very aggressive pad. It worked well and was easy to control but didn't seem all that aggressive. I switched to the Edge yellow and immediately could tell a difference. The larger pore pattern of the yellow cutting pad resulted in slighly more bite. The rotary was now harder to get to glide over the paint. Also I was able to haze the paint with the yellow pad and Megs pad didn't do that. The Megs burgundy will provide a better finish but the Edge yellow definitely cuts more. I feel as if the majority of the cut was provided by the pads vs the OHC.
2000 WS6 TA NBM
