Originally Posted by 01bluecls
I have used the rotary for quite a few details and already have two wool pads but have never used either. Any general tips for using them via rotary? I mean if I cant get some scratches, swirls out with Yellow LC with Menz PG at 1500rpms, then with a wool pad at the same rpms, working time, and PG would do the trick? Guess im trying to figure out how to use the wool vs a normal pad. From what I understand the wool via rotary will build up heat faster, so in theory I should reduce the working time of the polish? Sorry for the wool newb questions...
Just keep in mind wool cuts twice as fast as the yellow pads...nice thing is that they generate very little heat. Be careful on corners.
I don't like PG with wool, though I love PG with foam pads. Get your hands on some HTEC for use with wool (*and foam for that matter).
Feel free to run the wool a little faster (I'd rather run faster and use less pressure than slow with lots of pressure).
Spur the pad frequently or you'll get buildup that will "gouge" a few deep swirls here and there.
If you're working on an isolate scratch, feel free to put the pad up on end a little...this will focus a ton of cutting power on a small area.
Experiment with the twisted wool style and the flat lambs wool style - I use each for different purposes.
Let me know if you have any further questions.
