The paint on a car with a clearcoat is made of usually of two or three stages: primer, colour coat and lacquer. When polishing, either by hand or machine, we are abbradding away a very small layer of the lacquer/clear coat in order to remove the paint defects.
If you polish too far using to aggressive a compund, then it is possible to remove all of the lacquer coat and end up through to the colour coat - this is known as "striking through",and I'll demonstrate that here.
First of all, start with a three-stage painted panel - this has just been polished with Farecla G3 to an excellent finish:
Now, paint thickness readings were taken and revealed paint to be around 85 - 90um. This is very low thickness, and on a detail if you were to measure this thickness of paint then you wouldn't take any aggressive compounds to the paint... and this is why! I polishes the area by rotary polisher,
Meguiars polishing pad and Farecla G3. One set of passes to thorighly break down the product, lift up the machine and here's the "yellow" pad:
This is a big indicator that you have struck through the clearcoat as you are no polishing colored paint and the pigment is dying the pad... Looking at the area polished now, we can see what a struck through area looks like:
