Which
Intensive Polish is it you using? PO91L or PO85RD3.01? The former is the standard IP, has a very bruttle abbrassive and dries out quickly especially in the heat. The abbrassive is also very fragile, and shatters under pressure and doesn't properly break down ar work effectively. When using PO91L I spritz QD on the pad to keep things moist, spread at speed 3, and then make slow passes with no pressure at speed 3 until the residue goes clear (but not dry). Then I sprtiz the pad with QD and return the polishing at speed 3, the residue hazes up again... repeat this a couple of times, then up to speed 5 with no pressure and finally finish at speed 6 with medium pressure. QDing the pad everytime the residue goes clear. This is slow, but makes full use of the abbrassives by not shattering them under weight but letting them break down naturally. Achieves better results and a sharper finish.
If its the cerami-clear PO85RD3.01, the above does not apply - its much better lubed so doesn't dry out like the PO91L and uses a much less brittle abbrassive so can withstand light to medium pressure straight away.
