Grinding wheel 5"
Wire cup brush 3-1/2"
Sanding disc 5"
No load speed 10,000 RPM
AMPS (115V) 6.4
Spindle thread 5/8" - 11 UNC
Overall length 10-7/8"
Net weight 3.9 lbs.
Shipping weight 6.25 lbs.
Warranty: [Warranty Info]
Makita 9528PB
5" Angle Grinder
Features
Extra large paddle switch for easy operation right or left handed
Small circumference barrel grip for easy handling
Lock on button for continuous operation
Powerful 6.4 AMP motor, yet very light weight
High power-to-weight ratio
Spiral gears for efficient power transmission
Labyrinth construction seals motor and bearings from contamination
Spindle lock for easy accessory changes
Double insulated
Standard Equipment
1 Ea. 5" Grinding wheel (741407-8-1)
Lock nut wrench (782412-6)
Side handle (152487-3)
Lock nut (224509-0)
Inner Flange (224332-3)
Wheel cover (165055-3)
