Old 07-25-06, 06:17   #1 (permalink)
HenrikP's Avatar
HenrikP is offline
HenrikP is an unknown quantity at this point
Rotary RPM
whats the recommended range for opperating a rotary at (RPM) for different buff jobs (water spots, scratches, overspray etc.)?
Learning How To Detail the Eco-Friendly Way
Old 07-25-06, 08:26   #2 (permalink)
RogueM3 is offline
RogueM3 is on a distinguished road
Send a message via AIM to RogueM3
Anywhere from 1000-1600 seems to be the safe operating range. Alot of products also list the optimal RPM at which they should be used.
1995 Avus Blue M3
Recent Details: http://gallery.rennlist.com/gallery/album558
Old 07-26-06, 07:44   #3 (permalink)
lawrencea is offline
lawrencea is on a distinguished road
We always used 1400 to 1800 rpm.
Old 07-26-06, 07:45   #4 (permalink)
Andrew
awahl63 is offline
awahl63 is on a distinguished road
I usually stay around 1400 but go up to 1700 occasionaly
Andrew Wahl
ACW Elite Detailing
Chicagoland Detailer (Barrington)
Old 07-26-06, 01:46   #5 (permalink)
~werd to yo mutha~
Way2SSlow is offline
Way2SSlow is on a distinguished road
Send a message via AIM to Way2SSlow Send a message via Yahoo to Way2SSlow
That's my answer as well.
94 Impala SS in the ONLY color
04 Ford Focus ZX3 in white (daily driver)
~werd to yo mutha~
Wade-----Gallery
Old 07-27-06, 08:41   #6 (permalink)
HenrikP's Avatar
HenrikP is offline
when would 1500 or below not be enough or at what occasions do you guys use 1800 for instance?
Old 07-27-06, 09:38   #7 (permalink)
Bad Boy Time Out
Anthony Orosco's Avatar
Anthony Orosco is offline
Anthony Orosco is on a distinguished road
Paint correction - (etching, sanding marks, halo scratches) Foam cutting/wool pads and an rpm of nothing higher than 1800
Swirl correction - (Fine grit sanding marks, light marring, swirls from compounding) Foam polishing/lambswool pads and rpm between 1200 and 1500 (This step will most likely leave you with swirls also but they should be fine swirls and the next step should eliminate them).
Final polishing - Fine foam pads and an rpm of 1000
Product plays a big role here also. One can't expect a swirl free finish using a fine pad with an abrasive cutting agent. So a fine pad needs to be used with a fine product to get swirl free or close to swirl free results.
Anthony
Old 07-27-06, 09:55   #8 (permalink)
Originally Posted by Anthony Orosco
Product plays a big role here also...
So true, even with regard to the speed you use.
Note that 1Z polishes are used at much lower rotary speeds than is normal, around 800rpms. The abrasives break down too fast at higher speeds so you work the product at a low speed and then bump it up if you want to do some final burnishing after the abrasives have broken down. It seems weird to run it so slowly, but Ultra/Extra does some serious correction at the low speed.
Old 07-31-06, 08:09   #9 (permalink)
Dubbin' is Rubbin'
MachB5's Avatar
MachB5 is offline
MachB5 is on a distinguished road
Today I did VW/Audi Paint. I ran at 1700 with a Yellow LC pad and OHC, then switched pads to WHite LC and PO106FF. I started 106FF at 1700 with some pressure at worked it down to 1100 with no pressure and very slow. My Hitachi has its dial within close reach of my operating thumb so it makes it easy to dial down or up on the fly. And I can usually tell what RPM I am at by sound. Came out with very clean paint.
