Part 3 - Steel Wool Test B
Now, I wanted to try out a more aggressive
Meguiars W7006 Burgandy pad and
Menzerna Power Gloss, so some deep swilrs were needed!!
A friend of mine who also has a new rotary (Aote, using Autoglym pads) joined me at this stage too.
We masked off the door into half and hlaf, and Bryan tackled one side and I did the other... I'll let Bryan tell you how he got on with his side of the door, using an Aote rotary with Autoglym and then
Meguiars pads...
On my half of the door, I went straight for Power Gloss using the W7006 Burgandy pad. Good spray of
Last Touch on the pad, the apply the product. Pad was primed at 600rpm, then PG was spread. Then I went straight to 1200rpm with no pressure and made a few passes, then added a wee bit of pressure and up to 1500rpm for more passes until the PG started to go clear. Stopped, sprayed the pad with Last Touch and repeated some more passes at 1200, then 1500rpm. Then stopped when it went clear again, and buffed off the residue. The result after one hit of PG:
Big improvement, but some deeper scratches remained, so the above process was repeated - after two hits of PG:
Nearly there, only the very deep ones remained... I suppose I could have finished the panel at this point, but I wanted to give it some abuse :devil: So, a third pass, this time with added pressure and for fun knocked the speed up to 2000rpm (no I wouldn't do this for real on a car, was just playing herre!!
: ). The result - well the scratces had pretty much gone, the panel got hot (was radiating heat) and for the first time I saw holograms clearly uner the Brinkmann light:
Ooops!
: But no paint burning, and the holograms were easily fixed - a little bit of Final Finish:
Bingo!
Happy with that!
All in all, I am pretty pleased with my first ever effort on the rotary... I'll improve with practice, there's plenty of paint left on that door and when it runs out, I'll just get another and practice spraying on this door!
: More practice, then I'll start to be willing to crack the tool out on a car for real.
A couple of things I noticed: with the Power Gloss, I got far less micromarring with the Makita than I did with the PC, Makita breaking it all down more effectively? PG was definitely easier to use on the rotary I found. Also, I actually found control of the rotary to be
easier than the PC - no vibration, and the device glides far more and doesn't kick or tug at all. It feels a very flowing tool to use.
Also had a shot of Bryan's Aote using the Autoglym pads, and I found this more difficult going. The Megs pads, IMO, knocked spots of the Autoglym ones as far as defct removal goes... Also found the Aote speed varied, even under no applied pressure which made it dmore difficult to predict and use. The Makita held a constant speed, and flowed much better as a result. Just my thoughts anyways. Bry tried out the Makita as well as the Aote so I'm sure he can comment on the differences he found too.
Next up, I will try out the Megs #80 and #80 combo by rotary and see what I get. The menzerna polishes seemed very easy to use. Watch this space! :thumb:
