06-16-06, 06:35
Yaemish is offline
Join Date: Jul 2004 Location: New York Posts: 122 | PC Burns I brought my car to the lot to trade in the other day and noticed at dusk I had some dull spots in the paint that were from the PC.
I don't want to make the same mistake on the paint on my new Cadillac so I want to iron this out before I work on it this weekend.
My other car was dark blue just as this is. In bright light it looked great but I caught it at the right angle the other day and was not happy with the dull spots there that were PC induced.
I used SSR2.5 and a yellow, not all the webbing came out on the only pass I did but the pad did manage to do this to the paint. So I didn't overdo the PC. Did I use too little SSR? It covered the entire area, the only thing I didn't do was go over it with a lighter pad. Do you guys think this caused it?
Maybe sqitch polishes? | |
06-16-06, 06:38
webstrive is offline
Join Date: May 2006 Posts: 55 | i think the yellow cutting pad and ssr 2.5 should be expected to leave some marring?
probably need to follow up with a 2nd polishing step a less aggressive combo | |
06-16-06, 06:40
| | turbos = life
autobahn is offline
Join Date: May 2006 Location: Minneapolis, MN Posts: 295 | yep, ssr 2.5 and a yellow pad is not going to cut it as a final polish. It will take out lots of imperfections but you'll have to follow up with a less-agressive polish. ssr 2.5 and a white pad might even cut it for a final step, at least that's what some say. | |
06-16-06, 07:21
Yaemish is offline
Join Date: Jul 2004 Location: New York Posts: 122 | So what I am seeing is just marring and nothing more? Just kick it down to a soft pad and less agressive polish? Can anyone recomment something they like better than the SSRs? | |
06-16-06, 07:24
Join Date: May 2006 Posts: 55 | i've tried optimum polish, and found it to be a great product. didn't notice any dusting and buffed of pretty easily. | |
06-16-06, 08:01
| | Banned
-Lebowski- is offline
Originally Posted by Yaemish So what I am seeing is just marring and nothing more? Just kick it down to a soft pad and less agressive polish? Can anyone recomment something they like better than the SSRs? | menzerna hands down | |
06-16-06, 08:31
| | Sir-Wax-A-Lot
01bluecls is offline
Join Date: Jun 2004 Location: Ashburn, VA Posts: 2,163 | Depending on the hardness of the clear coat, I have used a PC, Yellow LC pad and SSR2.5 on a 98 black ford explorer and didnt get any haze. I just went straight to hand wax. On the other hand, I did have to use a follow up polish on an 05 dark Nissan Altima when using the same combo.
__________________ Refined Detailing
Chris - Sole Proprietor | |
06-16-06, 08:34
| | turbos = life
autobahn is offline
Join Date: May 2006 Location: Minneapolis, MN Posts: 295 | it's all a matter of the paint.
what polishes do you have on hand? | |
06-16-06, 08:44
Yaemish is offline
Join Date: Jul 2004 Location: New York Posts: 122 | I just have the SSRs right now. I can most likley get my hands on some 3M over the weekend. If I want Medernza, I will have to order it online. | |
06-16-06, 03:23
mblgjr is offline
Join Date: Mar 2006 Posts: 721 | Use the SSR's but drop to a lesser pad (polishing). If you have SSR1, use it after the 2.5, but also with a polishing pad. It will finish out very nicely with no marring issues.
3M Perfect IT III is also great stuff. Use it with an orange pad (LC) on a PC speed 6. You will have no marring and it leaves a perfect finish. | |
06-17-06, 09:43
Yaemish is offline
Join Date: Jul 2004 Location: New York Posts: 122 | How come the 3M will not leaving marring with a harsh pad? Isn't it the pad hat does the marring? If thats not the case why bother with SSR? I can just use the 3M. | |
06-17-06, 06:28
mblgjr is offline
Join Date: Mar 2006 Posts: 721 | The 3M products are meant to be used with a rotary and have more oils in them, therefore, you can use the aggressive pad with the PC and have the product finish well.
PC, speed 6, LC orange pad, 3M Perfect IT III
The SSR's generally have a much shorter working time and yield the same results faster because they were meant to be used with a PC. | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 02:09. | | | |
