Old 04-26-06, 06:34   #1 (permalink)
Driven-528e is offline
Driven-528e is on a distinguished road
Question Rotary pad ?
For those experienced rotary users out there, are foam pads (such as LC VC pads) safer to use than a wool pad?
If so, to what extent are they safer?
Can they achieve the same or similar results as a wool pad?
I want to make the step up to the rotary but am very aprehensive and want to start out as gentle as possible, but still get quicker results than with a PC. My goal is to practice extensively before putting it to use...
I am planning on using LC VC 8.5" foam pads to start out with.
HTML Code:
http://www.topoftheline.com/85lakcounfoa.html
Are these good pads for a beginner rotary user?
Any help/advice will be greatly appreciated!
Old 04-26-06, 01:28   #2 (permalink)
Wool is cool!
gmblack3a's Avatar
gmblack3a is offline
Closed foam pads build up more heat then wool or waffle foam. There is little to no air under the closed foam pads. If you use a softer closed foam pad it will still build up some heat, but not as much as the "heavier cut" pads.
Bryan Burnworth
Peachstate Detail LLC
"Paint Polishing Perfection"
Atlanta Detailing
Old 04-26-06, 02:25   #3 (permalink)
Thanks for the response!
Also, do you have a size recommendation?
Old 04-26-06, 04:00   #4 (permalink)
Wool is cool!
gmblack3a's Avatar
I use the same foam on rotary that I do on the PC. excel detail.
Bryan Burnworth
Atlanta Detailing
Old 04-27-06, 03:54   #5 (permalink)
AKA Bajapat
holland_patrick's Avatar
holland_patrick is offline
holland_patrick is on a distinguished road
look in the good deal theads and you can see my pads for sale
