04-19-06, 09:10
Wally is offline
Orange peel removal tips...
Just got a call from some guy with a VW golf show car that has had repaint.
Problem is, the sides are heavely covered in orange peel.
The color is some brown-gold-orange effect paint, with clear on it.
I don't have pics but imagine the worst orange peel ever seen.
As he has some kind of discussion with the paint shoip, he wants it done by me, because next sunday there is a photoshoot for a well known magazine here in Belgium.
I have experience with rotary and PC, but wetsanding scares me a bit off, also because of that special color.
What if the orange peel is under the clearcoat ?
Things I have : - Rotary, PC, Optimum polish/compound, SSR line, SFX line...
All sorts of pads and applicators... the full monthy...
Sanding paper (2000-2500), rubber block
Patience....
How can I best start with this ?
Sorry, no pics, I left my camera at work...
Subaru Impreza Turbo : Ecutek ECU, SW Motorsport brakes, AST tarmac suspension, a crazy driver & lot's more....
04-19-06, 01:21
Wally is offline
In other words :
Could it be possible that some of the orange peel can be removed with Optimum compound and an orange cutting pad ?
Or with SSR 3 with an orange cutting pad ?
I find the sanding way a bit coarse...
04-19-06, 02:23
admac is offline
i'm pretty sure you can't remove orange peel just by using a polisher otherwise everyone here would have glass-flat paint surfaces. the only way to remove orange peel is to sand the surface down so that it's flattened. then you can polish it. polishing orange peel just gives you shiny orange peel as evidenced by thousands of photos on this very website.
if you're finding sanding the finish to be to coarse, then perhaps you're using too low grit sandpaper. i really honestly just don't think you'll be about to polish out orange peel.
04-19-06, 02:50
blargonator is offline
no worries
wetsanding is simple, in my autobody class we painted small panels and we had to wetsand and polish them once we were done painting, spraying clear, taping off to paint another color, then spraying clear. it looks great, i can post pictures if you want and we only went up to 2,000 <8- P
its simple, fill up a bottle with water, add 1 drop of Ivory soap (no additives, its just plain soap, don't use anything else.), spray onto said area and sand. check your paper every so often to make sure you don't get any little jibblies on your paper and use a squegee every so often to check the area, it should look like a matte finish i guess.
are you going to be doing the whole car by hand? or do you have a D.A. or something?
best of luck, and this is my first post on here
04-19-06, 03:13
Lounging Sound Radio DJ
blackf0rk is offline
I just wet sanded my big Marauder last summer, and there's nothing really to worry about if you're detailed, and go slow. Use wet sanding paper (2000 grit+) with water and a little bit of dish soap for lubricant; quick detailer too if you prefer.
Depending on the severity, you can see the orange peel being knocked down as you sand.
2003 4.6L V8 Black Supercharged Mercury Marauder
386RWHP 426RWTQ
LOUNGING SOUND - Ambient, Chillout, Lounge, Psytrance, Goa & More
04-19-06, 03:34
Wetsanding is simple the way minor surgery is simple
I'd stick with 3000 grit Unigrit paper myself. I soak it in a very slippery carwash shampoo.
And yeah, polishing (as opposed to wetsanding) only works on soft ss, primarily lacquer.
Remember that the rule of thumb is that removing more than .3-5 micron (.0003"-.0005") of clear will usually cause eventual clearcoat failure if the paint is exposed to normal amounts of sunlight/UV radiation.
It's *VERY* unlikely that the OP is in the color coat as a) that paint flows differently and b) the subsequent application of clear usually mitigates any uneveness anyhow. If there *is* OP/excessive texture in the color coat there's nothing that can be done short of a repaint.
04-19-06, 03:41
Hmm. I should try out simple surgery then.
386RWHP 426RWTQ
04-19-06, 03:44
Professional Detailer
Jimmy Buffit is offline
[quote]and there's nothing really to worry about [\QUOTE]
There is some good and proper advice so far...
But, PLEASE practice on a junk panel from a body shop!
Too many 19 yo punks give advice that encourages wet sanding, and never mention that one cannot recover from a wetsanding 'mistake'.
We work on many highend vehicles / enjoy a wonderful reputation, but we seldom wetsand...
Be careful.
Oh it can be done. By the right hands.
Some due dilgence will show you (Mequiar's Director of Training) Mike Pennington's super black Suburban, which truly has a perfect finish.
One more time. Be professional, practice, practice!
Can you afford the repaint?
We Clean Cars.
Not The Planet.
BLOG
Thank a Veteran.  :
04-19-06, 03:58
[quote]Hmm. I should try out simple surgery then.
I tried it in Viet Nam, without the sarcasm. Worked out pretty well...
But then, I didn't have a choice.
Now I do...
Jim
We Clean Cars.
Not The Planet.
BLOG
Thank a Veteran.  :
04-19-06, 04:04
Buffaluffagus
jvriii1942 is offline
Jimmy Buffit
Thank You.
Quality is a habit, not an act. - Aristotle
Detailer in Charlotte, NC
04-19-06, 04:36
Well, it came easy for me; wet sanding that is.
But that doesn't mean I meant that you throw caution to the wind.
386RWHP 426RWTQ
04-19-06, 06:07
602rwtq is offline
