Actually
Meguiars #9 Swirl Remover is NOT a pure polish, it is a cleaner polish with chemical and abrassive cleaners in it. #9 is a 3 on
Meguiars abrassiveness scale whereas #80 is only one notch above at a 4. As I stated earlier though, it is always best to start out less agressive and work your way up as needed.
What speed are you running the PC at??? I generally run mine at 4-5 and work #9 for a while. I generally work #9 until it is almost dry. I then go back with a quick detailer and a soft microfiber and wipe it off. #9 is a mild compound and it may take repeated applications.
#9 really should be able to at least make a dent in those swirls in my experience with 4 different Honda motorcycles of my own including the Goldwing and I have lost track of how many others belonging to friends I have worked on.
By the way rotts4u, where are you located???
