Old 04-03-06, 02:52   #1 (permalink)
jedi_force is offline
PC for narrow areas??
I haven't used PC before so I need some advices.. what pad size do people use
for polishing narrow areas like winshield frames and bumper edges? Is 4"" pad
appropriate? Or I should polish it by hand?
JF
Old 04-03-06, 09:36   #2 (permalink)
Sometimes even the 4" is too big. Then I'll either do it by hand (most often) or I'll use the edge of a larger pad (the part that overhangs the backing plate). The PC is so gentle that using the edge is OK if you apply a little common sense.
Old 04-03-06, 07:26   #3 (permalink)
Edison_Chen is offline
bit OT: would we PC around the rear emblem/badges?
REVscene.net
Old 04-04-06, 05:52   #4 (permalink)
I generally just run the PC right over them but I still have to do the tight spots around the emblems by hand. There's a limit to how often you oughta do this though, the emblems on my Jag are worn down around their edges from being polished so many times over the years. Hindsight being 20/20, I should've taped them. So if the car's a real keeper, I'd tape off the emblems and just do those areas by hand.
Old 04-04-06, 05:55   #5 (permalink)
Kayak detailer
White95Max's Avatar
White95Max is offline
I move right over my emblems with the PC. The only problem I've noticed is that occasionally the product gets pushed between the letters, and it's a bit of a pain to remove it.
As for the original question, I use 4" pads on narrow areas. If it's really narrow (<2") I'll just do it by hand.
Paul...
Old 04-04-06, 08:13   #6 (permalink)
BigO's Avatar
BigO is offline
While we're on the subject of emblems, any tips on cleaning the residual polish out of all the nooks and crannies?
Old 04-04-06, 10:38   #7 (permalink)
Driven Auto Detail, LLC
mshu7's Avatar
mshu7 is offline
Contact: Send a message via AIM to mshu7
How about a soft toothbrush? That's what I normally use for removing wax in tight cracks and crevices (sp?).
-Mike
A professional detailer you can trust!
Voted Best Auto Detailing in Central Indiana
WRTV6 A-List Business Guide
Old 04-04-06, 04:21   #8 (permalink)
I dunno...any toothbrush I've ever seen with synthetic bristles would mar automotive paint. I have some natural bristle toothbrushes that aren't as bad when they're wet, but I still don't use them on the good cars.
I'd either use a lot of buffing with a very plush MF or pull the cotton wadding off a Q-Tip (or use a makeup ball) and work it into the tight spots with a sharpened toothpick. I "flag" the end of the toothpick to make it a little safer (in case it pokes through) and I also soak it with #34 to soften it some more. We've had some detailed threads on this that might be worth a search.
