Old 04-02-06, 05:02   #1 (permalink)
Rupert Pupkin
jdoria's Avatar
jdoria is offline
Porter Cable vs. Rotary
I am very experienced with a rotary. I just bought a PC to apply wax and maybe a final polish.
I really see no need for the Porter Cable. I get a beter finish with the rotary and I can wax by hand. Is there sometihng I am missing with the Porter Cable usage? I want to return it, I dont think I will use it for applying wax again unless I get some storied from users.
Rotary experienced professionals, what do you use your Porter Cable for?
Old 04-02-06, 05:06   #2 (permalink)
Welcome 2 the KEVOLUTION
gmblack3a's Avatar
gmblack3a is offline
If you are "the man" with the rotary, then it seems like you might not find much use for a PC. I just started using a rotary, but I use the PC for applying prime and still with FPII. I imagine soon I might be using the PC for that (FPII) too.
Bryan Burnworth..KBM w/ orange pad link tips
Peachstate Detail LLC...KBM w/ Surbuf pad link tips
"Paint Polishing Perfection"
Atlanta Detailing
Old 04-02-06, 05:10   #3 (permalink)
Rupert Pupkin
jdoria's Avatar
jdoria is offline
I see. My impression of the PC usage for a detailing professional was that it was used to polish tough to get at areas and to apply/remove wax.
I guess it is a stepping stone to a rotary?
Old 04-02-06, 06:02   #4 (permalink)
gmblack3a's Avatar
All of my LSPs are done by hand, but yes some (myself included) do view it that way. Then again some very good detailers (Scottwax and Mike here in the Atl) pretty much do all their work with a PC. They might be more qualified to better answer you then I am.
Old 04-02-06, 06:41   #5 (permalink)
Rupert Pupkin
jdoria's Avatar
jdoria is offline
Lets here from those guys.
Any info ?
Old 04-02-06, 06:51   #6 (permalink)
I believe in you Eli
1 Clean WS6's Avatar
1 Clean WS6 is offline
My response to every "rotary versus PC" thread is the same... why use a sledgehammer when a simple ballpeen hammer will suffice?
I use the PC for 90% of my details because with the right pads, products and a healthy dose of patience I can tackle all but the worst cars. Even then...when I do break out my Makita for a compound session I always follow my work with a PC.
A DA whether it be a PC or a Cyclo is a necessary tool (just as a rotary is) for a detailer IMHO.
Another thing one has to consider is the idea that use of a rotary = professional. That is simply not that case. From my own personal experience I have had to correct many, many rotary butcher jobs. It is all a matter of the man behind the tool with his knowledge, experience and skill that will bring about the ultimate results of the detail.
Mike
My WS6
Old 04-02-06, 09:32   #7 (permalink)
South Florida Style
themightytimmah's Avatar
themightytimmah is offline
Sometimes I just can't get a panel quite hologram free with a rotary, due to very soft paints or just having an off day in general. Or, if I can't inspect a panel under bright lighting/sunlight. In that case, I'll make a final pass via PC (I use a Cyclo actually, but its pretty much the same thing) and a mild polish like Menzerna FP or Optimum to ensure that there is no hologramming left on the final product. If you're good enough with a rotary that you can leave a perfect finish every time, than theres no need for the PC. But I know that I'm not that good.
Old 04-02-06, 10:03   #8 (permalink)
EdLancer's Avatar
EdLancer is offline
The way I look at it, is that the rotary is a perfect tool for fast defect removal and if you are an experience user a one step tool for customers where speed and detailing multiple vehicles per day is part of the business game, but for my own vehicles the PC is that machine that adds the TLC when doing the final polish and applying the LSP. The PC or Cyclo is the detailing enthuasist's toothbrush for frequent upkeep of the paint !
2003 Rio Red Mitsubishi Lancer
Old 04-03-06, 03:43   #9 (permalink)
Rupert Pupkin
jdoria's Avatar
jdoria is offline
I cant figure out why the finish with the PC was worse than the rotary. I used a grey Lake Country pad and 3M foam pad glaze and then a blue Lake Country and Natty's. As soon as I pulled the car in the sun, I couldnt believe the amount of swirls in the finish.
I usually finish a car with a black 3M foam pad and foam pad glaze, wash it, then wax by hand and the swirls are kept to a minimum.
Old 04-03-06, 03:50   #10 (permalink)
Kung Fu Detailer
gtbaka's Avatar
gtbaka is offline
Longer working time with a PC.
Generally doing poorly cared for vehicles. I'd say my Rotary to PC ratio is. 80/20
Another reason why I prefer a rotary over a PC in most cases is it won't vibrate my hands to death like a PC.
Don
Equilibrium Engineering Detailing Services
Old 04-03-06, 04:48   #11 (permalink)
porta is offline
I use my rotary for compounding, polishing and finishing.
And I don´t buy the argument
"why use a sledgehammer when a simple ballpeen hammer will suffice?"
I can do the same job for much less time with a rotary compared to a PC or a Cyclo. Just use the right pads. You don´t have to use the "sledgehammer" IE wool pad and heavy compund on all paints. Just use a polishing/Finishing pad and medium/light compound. And follow with a finishing pad, fine polish and ~1200rpm. On very senisitive paints I have to Compounding, polishing and then finishing.
Voilá no holograms.
I am not a professional but I do this every time and I don´t see any holograms. I use strong halogens and inspect all my cars for ~15min before I take out them in the sun and inspect again.
The customers are very happy.
But with wrong pads, wrong compound, to high rpm and wrong monkey behind the steering wheel, then is the rotary a perfect weapon against flawless paints.
I use my cyclo for LSP:s but I don´t like the high rpms(3200) 2000 is enough.
PC/Cyclo is bullet proof.
Who dares wins
Old 04-03-06, 04:57   #12 (permalink)
Rupert Pupkin
jdoria's Avatar
jdoria is offline
Voilá no holograms.
Who dares wins
I agree with this also. I rarely get holograms unless I am lazy and do a sloppy job. My rotary never spins laster than its slowers setting. I polish the paint until the 3M product is completely gone. For me, a rotary is the only way polish a car. Since I spent $200 on a PC and a bunch of pads, I was hoping there was someting I was doing wrong, or had false impressions. I spoke to the owner of Poorbays and he reccommened I apply Natty's by hand, I did and I was impressed with the results over the PC.
Anyone want to buy a new 7424 Porter Cable with 3 Lake Country pads used on the nose of a Porsche Cayenne S one time?
