Old 03-16-06, 04:43   #1 (permalink)
Omnipotent User
SHICKS's Avatar
SHICKS is offline
How do I center a pad correctly?
I just got a new SFX pad in the mail and it's not like the LC pad in which my backing plate seems to fit perfectly on the velcro. This pad has an entire velcro side.
How do I center it properly? Do I just keep trying, then mark it with a permenant marker?
Thanks,
Steve
Old 03-16-06, 06:05   #2 (permalink)
AKA Bajapat
holland_patrick's Avatar
holland_patrick is offline
get the edge 2000 pads and don't have to worry about it every again..
Old 03-16-06, 06:26   #3 (permalink)
twitch's Avatar
twitch is offline
I usually eyeball it and get it as close as I can. If my twitchy a@@ can do it I am confident that you can too
You will like the Sonus pads... they are quality.
Scott - 04 G35 6MT Coupe - Club Flex
Old 03-16-06, 06:29   #4 (permalink)
No prep, no pride!
a.k.a. Patrick's Avatar
a.k.a. Patrick is offline
Centering is not all that important as the pad itself oscillates.......get it close and you good to go !!
Owner of Exceldetail.
CA Summers Suck!
Old 03-17-06, 01:24   #5 (permalink)
yankees1 is offline
Ditto! Get the Edge System and never worry about pad placement again!
Old 03-17-06, 05:46   #6 (permalink)
Volunteer1816's Avatar
Volunteer1816 is offline
Contact: Send a message via MSN to Volunteer1816
Centering the pad isn't as critical on a DA, but what about a rotary? Other than the EDGE pads, what other tips/tricks are there to center the pads? I use LC pads...if that helps.
THX!
VOLUNTEER1816
Old 03-18-06, 05:04   #7 (permalink)
MichaelM is offline
THX!
Depends on the backing plats you use. Some plates have a hole in the center for a centering tool (my Makita came with one, looks like a small piece of pipe) which works well with the LC pads. I mostly use the 6" flexible backing plates with LC pads and try to eyeball the hole in the pad over the nub in the middle of the plate. Takes a few tries sometimes but not a hassle.
Old 03-18-06, 05:18   #8 (permalink)
I see what you're saying. My backing plate is solid with no hole. I kinda figured out a way today. Instead of putting the pad on the backing plate, I put the backing plate on the pad...if that makes any sense. I set the pad on the bench and set the plate into the pad. I found it easier since you can actually see where the plate is going to seat once it hooks in. Just thought I would share...
VOLUNTEER1816
Old 01-09-07, 11:20   #9 (permalink)
Sergei is offline
Re: How do I center a pad correctly?
Resurrecting this thread... I am trying to find a device that would center a velcro pad exactly. I have seen these tools, but not able to find it. Yes, I read that it won't matter on a PC since it oscillates. However the oscillation will exaggerate more thus causing premature wear on the PC 7424/7336. I say this because the CW on the PC is designed to cause the oscillation effect. Improper placement of the pad onto the BP would exaggerate the function of the CW. Right?
Old 01-10-07, 06:21   #10 (permalink)
Self Professed Knowitall
Grimm is offline
I just had a thought. Cut a piece of cardboard to the profile of the pad. Then take the size of the backing plate and make measured marks around the peremiter inside that cardboard cutout. Then place the backing plate on the marks so that it is centered perfectly and trace the entire circle of the plate. Then cut that out of the center of the cardboard. Then when you put a pad on, just put the pad on a surface, then put the cardboard template on the pad and all you do is put the backing plate in the circle in the center.
Old 01-10-07, 10:26   #11 (permalink)
Sergei is offline
That sounds like a quick fix. Thanks...
Old 01-14-07, 06:56   #12 (permalink)
yankees1 is offline
Edge System!
