Old 03-11-06, 12:16   #1 (permalink)
Wool is cool!
gmblack3a's Avatar
gmblack3a is online now
First time with hitachi and excel pads
Tried out the new hitachi rotary on my white 91 acura legend. I bought this car back in oct and never had a chance to polish it. The previous owner had it repainted back in 97. It had a good amount of swirls. GTScott was giving me a hand.
Start with a yellow excel pad, the 6" BP and some menzerna PG. I think I was in the 1100-1200 rage just trying to get comfortable on the hood. I worked the PG for a little while, checking the heat every once in a while. Was not getting much heat or reduction in the swirls. So after 3 passes, Scott suggested that I move up to the orange pad and dial up the speed to approx 1500. After working the PG a little while longer it was starting to built up some heat on the surface (warm). Back the car out into the sun and was finally starting to see some results. Did the hood, roof and trunk. It still took about 2 passes and I would say we got about 75% of the swirls out. We where using some light stands in the garage later in the evening. Time was running out so Scott used the PC with FPII top go over the entire car and I applied a single coat of Werkstatts CJ.
I will continue to work on this car over the next few weeks.
Should I try a wool pad or something else with a little more cut? Still seemed like a slow process, but I'm sure I could not get these results from a PC.
Got some buffer hopping and that seemed to be from the pad getting loaded up from too much PG. Changing out the pads often seemed to help this. I did not feel that I was using too much PG, but working with white its hard to tell. The slinging did not seem that bad. I did have alot of dust.
On the lower panels it seemed hard to control the rotary.
Thanks for any tips!
Bryan Burnworth
Peachstate Detail LLC
"Paint Polishing Perfection"
Atlanta Detailing
Old 03-11-06, 12:26   #2 (permalink)
wannafbody is offline
I wouldn't go any more aggressive than a Medium cut pad with a rotary. Maybe a stronger compound???
2000 WS6 TA NBM
Old 03-11-06, 01:23   #3 (permalink)
Wool is cool!
gmblack3a's Avatar
I think the orange propel is considered a "heavy" cut pad.
As far as I could see no micro-marring or buffer trails.
Bryan Burnworth
Atlanta Detailing
Old 03-11-06, 01:53   #4 (permalink)
BE(beginning experience)
cwcad's Avatar
cwcad is offline
cwcad is on a distinguished road
Not being a pro I guess that I do not know any product stronger than Menzerna PG.
I guess that I would do it over again. Do the same thing but with slower passes. I am not able to get what needs to be done with just two passes. I am wondering if the product had been worked completely. I have found when using Menzerna PG that there is a haze that needs to be removed with another polish like FPll when worked long enough to get the job done.
cwcad
DO WHAT YOU SAY... SAY WHAT YOU DO!
www.ldkbox.com a blog agbout life's details
Old 03-11-06, 02:04   #5 (permalink)
Wool is cool!
gmblack3a's Avatar
Thanks!!! Will polish for a longer time when I get to continue.
Bryan Burnworth
Atlanta Detailing
Old 03-11-06, 03:12   #6 (permalink)
Jimmy Buffit's Avatar
Jimmy Buffit is offline
First, you prolly won't see buffer swirls on a white car except in the bright sunliight.
If you are only getting 75%, then you might want to increase
a) speed,
b) pad 'strength' or,
c)a more aggressive polish.
But, what many of us overlook, maybe just a few more passes with your current combination (more polish) will do the job. I *frequently* find this to be the case in my shop...
Jim
Proud Member of NAPDR
Thank a Veteran. :
Old 03-12-06, 05:28   #7 (permalink)
Wool is cool!
gmblack3a's Avatar
Thanks Jim!!
I was working on the rear plastic bumper cover today.
Here is a pic before I started:
After 3 passes @ 1500 with PG and orange excel pad:
These are pretty "minor" swirls IMO, so its still taking me a while to get them out.
I have a wool/poly pad Should I try and use it? Or is there something inbetween the foam pad I am using now and that.
What about this foam waffle pad?
TIA!
Old 03-12-06, 05:36   #8 (permalink)
I believe in you Eli
1 Clean WS6's Avatar
1 Clean WS6 is offline
1 Clean WS6 is on a distinguished road
I beg to differ!!!! Just takes a little more time and some patience.
I agree with Jim. Keep your speed at 1500, slow your pass speed down and make multiple passes with your current product/pad combo. The rotary is a great tool but will not remove everything in one pass.
Mike
My WS6
Old 03-12-06, 06:20   #9 (permalink)
Wool is cool!
gmblack3a's Avatar
Thanks Mike! I guess I need to look on the bright side and that is nothing is getting messed up.
Old 03-13-06, 04:19   #10 (permalink)
Mammal
GTScott's Avatar
GTScott is offline
GTScott is on a distinguished road
Send a message via AIM to GTScott
WS6 - I don't agree with you at all. No reason, I just feel that today is a good day to not agree with you. Sometime I need to lure you over with offers of free beer to critique our process.
I was surprised at how slowly the process went. I assumed the rotary would be the magical swirl eraser and it was not. Still, a great tool I am glad to have in the arsenal.
-GT
Old 03-13-06, 09:40   #11 (permalink)
Wool is cool!
gmblack3a's Avatar
Here is the trunk all done. I had removed the wing to do this.
Power gloss 59,625 times
IP 2x
FPII 1x
Nattys blue
Poor boys Spray n Gloss (SnG)
When I get done polishing the entire car, I will werkstatt prime, AJx2 then CJx2 a week or so later.
