| Did you try misting the pad with distilled water or QD during polishing? I've found that this has really helped me with buffer hop/holograms in the past. For a second step, I'd use FPII or SSR1 on a green pad. Blue doesn't really have the cut to follow up and remove any holograms on harder paint. I do keep a blue pad around, however, for use with DP FFP or PO85RD to finesse super soft paints that haze with the green/FPII combo.
