Originally Posted by viper531
the counterweight came installed on my pc when i bought it. i guess i will have to get used to the vibration. i'll try it w/o the handle next time around.
Excess vibration could be because you are using the wrong counterweight for the wrong pad size. The counterweight already installed in the 7424 is for 5" pads. If you are using pads bigger than 5" than the PC body can be used as a nice massage tool for your aches and pains.
Order the #6 counterweight for larger diameter pads and the vibration should decrease significantly.
This is also important to work as well. In physics it has to do with energy transfer. If your unit has too much vibration that means most of the energy to do work is being transferred into your arms as opposed to being transfered to the pad and doing work on the car surface.
