02-03-06, 03:30
BANNED FOR SPAMMING
SVR is offline
To dampen or not that is the question
With all menzerna polishes, is it best to simply apply the 6 inch line and buff away or must I dampen the pad and maybe the surface
Mizzuri used PO85RD without any water and wow, what a result
I am finding myself having to dampen the pad half way through doing a panel otherwise the product won't completely break down and dissappear
Start at 600, up to 1000 then 1200-1350 and back down to 900 and all done is my method
Did the hood last night with FP II and VM, RMG, YCW - WOW
02-03-06, 03:47
scottabir is offline
I dont spray anything on the menzerna polishes because they get runny real quick with even one spritz to "prime" the pad.
2003 Mazda 6S black
Do what you love and the money will follow
02-03-06, 04:13
BANNED FOR SPAMMING
SVR is offline
OK thanks, I'll try without water
02-03-06, 05:57
3Dog is offline
I always "mist" my pad. Not dampen or soak but mist.
Ric
3Dog Garage
HOGtailing is my business
02-04-06, 04:43
T.W. Tib05 is offline
I second 3dog!
02-04-06, 06:17
Buff Guy
RAG is offline
I use Menzerna a ton (probably about a quart a week between the different polishes), so I think I speak from good experience. With FFII I sometimes prime the pad (barely) with a spritz or two to get a little longer working time, though it really isn't necessary. With IP I never prime, as it is already quite wet and works for enought time to break down completely. With PowerGloss I add wetness to the polish by adding about 20% of another, more wet compound (lately Optimum's Hyper Compound)...this seems to create the ideal consistency. With the right pad, I can easily run in the 2000 RPM range (or higher) with zero splatter.
BTW, you shouldn't have any problem getting the polishes to "break down" with a rotary. And feel free to turn the RPMs up once you get more comfortable with the rotary, this will give you more polishing action in less time.
You'll have to excuse me...I just learned how to take pics with my phone and upload them here...but this was with Menzerna PG and then #9 the night before last:
After polishing
02-04-06, 07:24
I don't have much to add
SpoiledMan is offline
Did you say 2000 RPM with the rotary??? That's way too fast for most any product and out of Menzerna's recommended speed for sure. Keep it around 1000-1200 RPM. I do find that a spritz is good with PG but not necessary with IP or lighter and just a bad idea with the "nano" polishes.
Black cars are fun!
02-04-06, 09:17
3Dog is offline
My giving one (and only one) light "mist" to a clean pad has nothing to do with my polishes...I am anal and dont like setting a completely dry pad on my paint.
Ric
3Dog Garage
02-04-06, 08:27
Buff Guy
RAG is offline
I hear you spoildman. I don't always run at 2000, but I usually hang out in the 1500 to 1800 RPM range. Without a doubt, I can get more done faster at 1800 then I can at 1200. As long as you know what you are doing and don't generate too much heat, it isn't a problem; and the LC pads I use generate very little heat if moved around properly. I've used about every pad made (literally) and some pads generate too much heat when ran at high RPMs, so one must excercise caution when turning up the volume. I think I'd go cazy if I compounded an entire car without exceeding 1200 RPMs. But everybody has there own thing...I've simply found that operating at higher RPMs allows me to get the job done faster, and I haven't had any problems yet.
Also, one thing people have to keep in mind when considering recomended speeds - these recomendations were made with 9" pads in mind. The edge of a 9" pad travels a heck of a lot faster than a 6" pad at equivalent RPMs.
02-04-06, 08:58
I dunno, when I'm working on a $90k BMW I tend to want to take my time. I'd really hate to have to repaint even a single panel trying to save a few minutes.
Black cars are fun!
02-04-06, 11:06
BANNED FOR SPAMMING
SVR is offline
With you spoiledman
All I have ever done are two mists of water on a pad
Tried all products without water and worked sensationally
Worried a little about dry buffing problems but so far no probs
As usual your feedback is very helpful
02-04-06, 11:40
 Just got finishes beard trimming and saw this. I'm glad that I could be of help!
Black cars are fun!
