01-28-06, 03:50
lucaszcpm3 is offline
Join Date: Jan 2006 Posts: 175 | Right speed's to use the Dewalt DW443 at Hi all, sorry for the noob question but is there a list of the right speed's to use the Dewalt DW 443 at. For example what is that right speed to use Poorboys SSR 2.5 and so on? Any help would be great, and yes I did do a search. Lucas | |
01-28-06, 04:52
3Dog is offline
Join Date: May 2004 Location: Nashville, TN Posts: 1,133 | You can spread at a slower speed..around 2..always making sure your pad is on the paint..then kick it up to 5 or 6. Remember the Dewalt is a little faster..6 being 6800 OPM.
Ric
3Dog Garage
HOGtailing is my business
02-03-06, 05:36
Join Date: Jan 2006 Posts: 175 | So 6800 is not to fast  | |
02-08-06, 03:36
Join Date: Jan 2006 Posts: 175 | BUMP anyone, Thanks | |
02-08-06, 03:38
| | Ari Gold
G35stilez is offline
Join Date: Jul 2003 Location: Southport, CT Posts: 6,667 | 1200-1500 rpm for light polishing
1200-1500 rpm for medium polishing
1500-1800 rpm for heavy polishing
This is my general rule of thumb.
__________________ '02 Escalade | |
02-08-06, 05:44
| | Waxophile Autojourno
Bence is offline
Join Date: Jun 2004 Location: Hungary, Europe Posts: 2,462 | The 443 is a DA. But Sean's rotary RPMs are good. In some cases you can bump it over 2000 but that for wool pad work and it is rarely needed.
Regardless of machine, you can use the above mentioned speeds with every DA. 3-4 for spreading, the above for polishing. The higher the speed, the heavier the correction.
Don't worry about the exact OPMs. There are DAs that have smaller pad throw (3-4 mm), but they are compenstaing this with a significantly higher OPM number (up to 24.000). This ultra fast jiggle often breaks down even the more difficult polishes pretty quickly. It finishes up the coarser ones to LSP-ready levels too. The slower ones, such as the PC have a quite big, 8.8 mm pad throw. That means heavier vibration. A good compromise is a powerful machine with a 5-6 mm pad throw and a 6000-8000 OPM capability. | |
02-08-06, 05:50
wannafbody is offline
Join Date: Feb 2005 Posts: 5,573 | doesn't dual action refer to both a rotational and orbital (not round) movement?
2000 WS6 TA NBM
02-08-06, 05:52
Bence is offline
Join Date: Jun 2004 Location: Hungary, Europe Posts: 2,462 | No. DA is the orbital. | |
02-08-06, 06:06
Join Date: Feb 2005 Posts: 5,573 | Bence- I have a cheap random orbit polisher and it seems to both wiggle and rotate(under light to moderate pressure) I guess under heavy pressure it might not rotate. Do all RO polishers work this way?
2000 WS6 TA NBM
02-08-06, 07:31
Bence is offline
Join Date: Jun 2004 Location: Hungary, Europe Posts: 2,462 | Yes. They are all drawing an uneven (random) daisy-like pattern (orbit). | |
02-09-06, 03:42
Join Date: Feb 2005 Posts: 5,573 | Thanks for the clarification
2000 WS6 TA NBM
02-12-06, 04:54
velobard is offline
Join Date: Nov 2005 Location: Kirkwood, MO Posts: 1,840 | Quote: |
1500-1800 rpm for heavy polishing | Sean, according to the specs, the speed range on the PC is 2500-6000 OPM. | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 01:59. | | | |
