Originally Posted by Danase I used the wool pad once and it left all kinds of marks in the paint I had to remove with the foam pads. However, I know a lot of guys who use the wool pads at a low speed for removing the lsp. |
Bob is right, youre going to ahve to add another step in your process to remove the marring left from the wool pad. This wouldnt be bad if a wool pad was a lot more aggressive then a foam heavy cut pad, but my experiences is that it is only marginally heavier of a cut that isnt justified by its results.
-Justin
