12-30-05, 10:14
| | Zaino Whore
Guido is offline
Join Date: Nov 2005 Location: Queens, NyC Posts: 43 | Is it easier to mar the paint with a machine? I used to put my zaino on by hand. Lately I've been doing it with a PC and one of the finishing pads that was recomended in another thread. I've found a few small micro scratches in the paint that are in an even loop design. I put the polish on between 5 and 6. Would spraying detailer on the pad help?
thanks | |
12-30-05, 10:41
| | Kayak detailer
White95Max is offline
Join Date: Jan 2004 Location: Stevens Point, WI Posts: 6,885 | I doubt a finishing pad would cause any marring. It's more likely that there was some dust on the pad/car or something. Or maybe the pad was used in the past with a polish, and the abrasives weren't completely broken down, leaving some abrasives in the pad?
__________________ Paul...
12-31-05, 03:23
White_F150 is offline
Join Date: Jul 2001 Posts: 556 | When using any tool to apply product (hand applicator, PC pad, or rotary pad), make sure the pad is "primed" before it touches the paint. Using a QD will work "sometimes"... depending on the product being applied. I like to make sure the pad is fully primed with the product that I'm going to apply... whether it be a paint cleaner, polish, wax, or sealant.
__________________ White_F150 | |
12-31-05, 07:30
| | Zaino Whore
Guido is offline
Join Date: Nov 2005 Location: Queens, NyC Posts: 43 | yeah i figured it was dust on the pad or on the car but the pad is brand new, I put the z2 on and let it sit for 45 minutes and covered the pc w/ finishing pad with a plastic ziplock bag. How much more dust free can I get?
white f150- what do you mean prime the pad? | |
12-31-05, 08:14
| | Practical Perfectionist
Join Date: Sep 2002 Location: NE Ohio Posts: 20,415 | I can't see how *what's moving the pad around* could make a difference. Whether the machine moves it or your hand moves it, it's still just a matter of the pad contacting the paint. Must be either something between the pad and the paint or the pad being/becoming dry at some point. IMO the "loop design" of the marring almost guarantees that some contamination caused the problem.
But light sealants are one thing I prefer to do by hand anyhow, easier for me to get 'em on very thin. | |
12-31-05, 12:53
| | Kayak detailer
Join Date: Jan 2004 Location: Stevens Point, WI Posts: 6,885 | Priming the pad refers to using water, QD, or the product to get the pad moist before using it on the paint. The idea is that a dry part of the pad may cause marring on the paint. Also, with products like AIO, a light mist of water on the pad helps to spread it thin.
12-31-05, 06:36
Mike-in-Orange is offline
Originally Posted by Guido I put the polish on between 5 and 6. | FWIW I apply waxes/sealants using my PC at a much slower speed, like 3, and just let the weight of the machine sit on the surface, if that even. I'm able to put a much thinner, more uniform layer on this way than I can by hand. I do prime the pad before hitting the paint. | |
12-31-05, 07:19
| | Now with twice the head
Join Date: Oct 2001 Location: Arlington, TX Posts: 25,215 | Quote: |
Originally Posted by Accumulator Must be either something between the pad and the paint or the pad being/becoming dry at some point. IMO the "loop design" of the marring almost guarantees that some contamination caused the problem. | Agree 100%. I learned the hard way on my own car when I got something caught under a Meguiars burgandy cutting pad. Took quite some time to get about 90% of the scratches out, the other 10% you can only see from certain angles.
12-31-05, 08:36
zey is offline
Join Date: Nov 2001 Location: Kuala Lumpur, Malaysia Posts: 296 | Quote: |
Originally Posted by Guido I used to put my zaino on by hand. Lately I've been doing it with a PC and one of the finishing pads that was recomended in another thread. I've found a few small micro scratches in the paint that are in an even loop design. I put the polish on between 5 and 6. Would spraying detailer on the pad help?
thanks | Guido, I term that "micro scratches in an even loop design" as micro marring. | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 10:22. | | | |
