12-18-05, 03:56
cowgirl is offline
Join Date: Dec 2005 Posts: 1 | PC but what pads?! Being new to this stuff, I just bought myself a nice PC  Ive been trying to research on what pads to get but there seems to be a mixture of responses. I have heard both good and bad things about Sonus, Propel, Lake Country, Meguiars pads. Just wondering which ones everyone prefers and if you know a good place to purchase them on the net!
Thanks | |
12-18-05, 06:42
BigAl3 is online now Join Date: Mar 2005 Posts: 6,132 | give patrick a try at www.exceldetail.com and he'll guide you in the right direction.
they just got in the new propel 2 pads (you'll need a backing plate as well) and i plan on getting those next. | |
12-19-05, 07:23
| | One Shiny tC
Neothin is offline
Join Date: Jun 2005 Location: Port St. Lucie FL Posts: 1,746 | Whichever pad you end up choosing I recommend that you get a cutting, light cutting, and polishing pad in a small 4" size and have a few polishing and finishing pads in a larger size. Many PC users including myself find that 4" pads not only aid defect removal with abrasive polishes but also find them easier to get into tight spaces on the car. I personally have lake country pads and have only had one problem with them. I was using a 4" polishing pad and after 3 hours of polishing my car with PO85RD i went to take the pad off to wash it and the pad had fused with the backing plate.
__________________ 2006 Nautical Blue Metallic Scion tC
Mods can be found HERE
AIO-RMG-Souveran
12-19-05, 08:35
| | Kayak detailer
White95Max is offline
Join Date: Jan 2004 Location: Stevens Point, WI Posts: 6,885 | I prefer the Propels from ExcelDetail, in both 4" and 6.5" size. I haven't tried the P2s, but I'm getting those next.
__________________ Paul...
12-19-05, 08:45
tumbler is offline
Join Date: Jun 2003 Location: Toronto, Canada Posts: 1,448 | I solely use sonus pads. Used Lake country in the past and did not find them durable enough | |
12-19-05, 10:48
Lowejackson is offline
Join Date: Jun 2001 Location: UK Posts: 3,871 | I would suggest you should get good results with any of the pads mentioned. Preferences play a big role here. It is not the pads which make the big differences, it is you | |
12-19-05, 11:11
3Dog is offline
Join Date: May 2004 Location: Nashville, TN Posts: 1,133 | Quote: |
Originally Posted by Neothin Whichever pad you end up choosing I recommend that you get a cutting, light cutting, and polishing pad in a small 4" size and have a few polishing and finishing pads in a larger size. Many PC users including myself find that 4" pads not only aid defect removal with abrasive polishes but also find them easier to get into tight spaces on the car. I personally have lake country pads and have only had one problem with them. I was using a 4" polishing pad and after 3 hours of polishing my car with PO85RD i went to take the pad off to wash it and the pad had fused with the backing plate. | I find this interesting. Can you explain why you used a 4" pad with a finishing polish on the entire car. Not flaming, just curious.
Ric
3Dog Garage
HOGtailing is my business
12-19-05, 12:14
hood rich is offline
Join Date: Nov 2005 Posts: 42 | i was really impressed when i bought the green foam polishing pads for german paints from properautocare.com.... i use this pad to polish all the vehicles i do. it does a great job, no complaints yet. | |
12-19-05, 01:36
| | Vee-dub in da hauz, yah
Sherman8r44 is offline
Join Date: Sep 2005 Location: Lawng Oiland, New Yawk Posts: 1,065 | Quote: |
Originally Posted by 3Dog I find this interesting. Can you explain why you used a 4" pad with a finishing polish on the entire car. Not flaming, just curious. | I have to also add, why 3 hours with a finishing polish  | |
12-19-05, 01:59
| | One Shiny tC
Neothin is offline
Join Date: Jun 2005 Location: Port St. Lucie FL Posts: 1,746 | Because it was my first time using the polish and I wasn't used to how long it took to break down so I had to redo areas a couple of times. Also when doing the vertical panels everytime I moved the light stand I found more swirling. There was also a 1/2 hour break in there for dinner and time for taping off trim and such. I wasn't really in a rush either. The reason I used a 4" pad is because I use smaller pads for defect removal no matter how big or small.
AIO-RMG-Souveran
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 06:33. | | | |
