12-12-05, 07:22
| | Detailing n00b
Jliao is offline
Join Date: Feb 2003 Location: Thousand Oaks, CA Posts: 202 | What's all these dusts coming off my pads? Whenever i work with DACP, PO106FF, at speed around 5. I get all these dusts coming off especially at corners of the car. Am I doing something wrong? It seems I may be doing it too fast, perhaps I need it work it at a lower speed?
Thanks | |
12-12-05, 07:26
| | Kayak detailer
White95Max is offline
Join Date: Jan 2004 Location: Stevens Point, WI Posts: 6,881 | Does your pad have some dried polish in it from a previous use?
__________________ Paul...
12-12-05, 07:37
| | One Shiny tC
Neothin is offline
Join Date: Jun 2005 Location: Port St. Lucie FL Posts: 1,746 | i recently used PO85RD and noticed that after you work the polish for a while, it does dust considerably. PO106FF is the same thing as 85RD except that it has a higher concentration of abrasives. It should dust just like 85RD does.
__________________ 2006 Nautical Blue Metallic Scion tC
Mods can be found HERE
AIO-RMG-Souveran
12-13-05, 01:57
JBM is offline
Join Date: Dec 2004 Location: Florida Posts: 1,626 | Use less DACP. After my pad is primed i use only like 4 pea sizes drops. | |
12-13-05, 04:27
| | One Shiny tC
Neothin is offline
Join Date: Jun 2005 Location: Port St. Lucie FL Posts: 1,746 | I'm going out on a limb and thinking that you've never polished with a PC before. If so, some polishes do dry out and create dust when your polishing. Some are worse than others. The poorboy's SSR series creates alot of dust while polishes like those made by Optimum create very little to no dust at all. Don't be alarmed when your polishes start to dust up, its perfectly normal. You can use the dusting as a sign that you need to add more polish to the pad soon.
AIO-RMG-Souveran
12-13-05, 08:02
| | Detailing n00b
Jliao is offline
Join Date: Feb 2003 Location: Thousand Oaks, CA Posts: 202 | Initially I thought was the same thing -- compound dried out from previous use. Although, I can't seem to see any (perhaps not thru naked eyes).
I've tried using less compound and lower speed.
Maybe my cleaning process for the pads isn't right? I basically let it sit in a bucket with dish washer soap (dawn) for a bit, then rinse it out. I then put it on PC to spin it to get the water out.
How do you guys clean the pads? | |
12-13-05, 08:49
| | Kayak detailer
Join Date: Jan 2004 Location: Stevens Point, WI Posts: 6,881 | I always scrub the pads a little bit before rinsing out. I'd recommend that you try that.
12-13-05, 09:09
| | One Shiny tC
Neothin is offline
Join Date: Jun 2005 Location: Port St. Lucie FL Posts: 1,746 | well, instead of using the "scrub" I think he meant "massage" the pads with your hands before you rinse them out.
AIO-RMG-Souveran
12-13-05, 09:10
| | Kayak detailer
Join Date: Jan 2004 Location: Stevens Point, WI Posts: 6,881 | lol, what's the difference? Yes I mean with my hands, as opposed to scrubbing with a toothbrush or something.
12-13-05, 09:34
| | One Shiny tC
Neothin is offline
Join Date: Jun 2005 Location: Port St. Lucie FL Posts: 1,746 | I didn't want him to think that you said to use a tire brush or something
AIO-RMG-Souveran
12-14-05, 09:12
| | Detailing n00b
Jliao is offline
Join Date: Feb 2003 Location: Thousand Oaks, CA Posts: 202 | Actually, I do somewhat scrub it, then in the process of rinsing it I rub it as well. | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 05:17. | | | |
