Old 11-14-05, 11:13   #1 (permalink)
CoryB is offline
Killed a pad. What did I do wrong?
Disclaimer: I'm new to machine polishing and still learning.
So I'm happily polishing away on my MINI Cooper with my PC, orange Sonus DAS pad and Z-PC. Suddenly I start seeing little bits of orange foam fly. I immediately turn off the PC and look at the pad.
The velcro backing is peeling away from the foam and the back of the pad is HOTTT.
Environment: I was alternating between speeds 3.5 to spread the Z-PC and 5.5-6 to polish out the microscratches. When I first started I sprayed one light shot of Z6 on the pad and then put on an X of Z-PC across the pad. I reloaded the Z-PC as needed (when it cleared/dried/started dusting). I got the bonnet (hood) and 1/4 of the roof done before the pad self-destructed, and I noticed that the PC seemed to be laboring a bit before the pad came apart. I finished the roof with a Sonus green pad and had no other problems.
Any thoughts or hints on what I was probably doing wrong to cause this?
FWIW, the velcro is separated about a quarter of the way around the foam and there is apparently no glue in the center of the pad from what I can tell. Can this be fixed with shoe-goo or should I just chalk it up to learning and replace the pad?
Old 11-14-05, 11:36   #2 (permalink)
beachcities's Avatar
beachcities is offline
that has happened to me plenty of times. but buffing with a porter cable?? get real man. porter cable is an orbital buffer, how can you expect to do any real work with some thing that does not even create heat? get your self a dewalt, or a mikita, a single motion, non orbital. but the reason the pad flaked, ususally on the edges, is beacuse there was no product in that particular spot, and when it hit the car it created too much friction, and the pad flaked
Old 11-14-05, 11:45   #3 (permalink)
Dacali is offline
I've never had that happen to me with my PC and pad kit from CMA. I would figure the back of the pad would stay cool since it's moving with the backing plate (no friction). In fact, I've never had my pads get THAT hot before even on 6. Was the pad level with the car? Hopefully someone with more experience with the PC can help you out.
I feel much safer with a PC than with a rotary. It may take longer to work and require the right products, but it can light imperfections. I'd recommend anyone who's not ready to use a rotary!
-Dacali
Old 11-14-05, 11:45   #4 (permalink)
Red98gt's Avatar
Red98gt is offline
ahhh, A PC no good? Funny, a lot of people here like them! Sounds to me like you have no idea what you are talking about there beachcities....
07 Nissan Titan
02 GMC Envoy
Old 11-14-05, 11:56   #5 (permalink)
Time's a-wastin',speedy!
TortoiseAWD's Avatar
TortoiseAWD is offline
Contact: Send a message via AIM to TortoiseAWD
Cory,
I've noticed pads heating up, too . . . I'm pretty sure it's a side-effect of the constant change of direction the velcro backing is dealing with. In my experience, I've never noticed the face of the pad getting hot; rather, the velcro backing begins to heat up from the orbital motion. As would be expected, it's a lot more common when you're running your buffer at high speed (5-6).
What can be done about it? Not much that I can think of, really, other than having several pads on hand so you can give a pad a "rest" when the backing begins to heat up.
And beachcities, you might want to do some browsing through the Click & Brag forum to see just what kind of "real work" can be done with a Porter Cable or Cyclo (most posters will list their process in the first post). A rotary is no doubt the fastest way to correcting paint, but it is possible to get similar results with an orbital given enough time, and a PC or Cyclo is certainly a much safer choice than a rotary for the weekend "enthusiast" detailer.
Tort
If you wish to make an apple pie from scratch, you must first invent the universe. — Carl Sagan
Old 11-14-05, 12:25   #6 (permalink)
Mikeyc's Avatar
Mikeyc is offline
This is undoubtedly the first time I have EVER heard anyone bad mouth the PC. Granted the PC cannot do all the work that a rotary can. The PC can accomplish a lot of what the rotary does sometimes though it takes a bit longer. On the plus side with a PC you don't have to worry about burning through your paint if you're a beginner which IMO is a big plus. I think you'll find the PC is in fact the machine of choice on this website as well as others. There's also a big fan base for the cyclo.
Old 11-14-05, 01:10   #7 (permalink)
General Lee's Avatar
General Lee is offline
2005 Toyota 4Runner SR5 4WD
2005 Jeep Wrangler Unlimited
1998 F-150 STX
Old 11-14-05, 02:23   #8 (permalink)
blkyukon's Avatar
blkyukon is offline
.....but buffing with a porter cable?? get real man. porter cable is an orbital buffer, how can you expect to do any real work with some thing that does not even create heat?
Would you consider this real work?
Before
After SSR3 and PC
Old 11-14-05, 03:21   #9 (permalink)
BE(beginning experience)
cwcad's Avatar
cwcad is offline
Before
After SSR3 and PC
da...Ya!
A picture is worth a thousand words is it not , blkyukon.?
cwcad
DO WHAT YOU SAY... SAY WHAT YOU DO!
www.ldkbox.com a blog agbout life's details
Old 11-14-05, 03:26   #10 (permalink)
Scottwax's Avatar
What type of backing plate do you have? The smaller ones tend to run a bit hotter (due to less surface area unable to dissipate heat as quickly) and heat is what can break down the adhesive holding the velcro backing on the pad. The Meguiars backing plate is especially bad with regards to heat retention-luckily, the new adhesive Meguiars is now using on their pads seems to hold up very well, haven't had one seperate in about a year.
A defective pad is also a possibility.
Scott's Mobile Auto Detailing
Old 11-14-05, 05:13   #11 (permalink)
CoryB is offline
I used the SonĂ¼s DAS pad kit from Autopia CarCare. The backing plate measures ~4 5/8"
Here are some pictures of the pad:
With a pen in place to show where the glue broke down.
And another picture of the pad without the pen.
Old 11-14-05, 06:50   #12 (permalink)
FrizzleFry's Avatar
FrizzleFry is offline
looks like pressing too hard w/ the PC... backing plate eating into the velcro.
